Author Topic: Changing Coolant: Any parts that I should get just in case.  (Read 4180 times)
Offline richandhazel
Re:Changing Coolant: Any parts that I should get just in case.
« Reply #10 on: 23 November 2003, 18:15 »
'6, are you thinking what I'm thinking?
The lower radiator hose will drain the radiator etc., but the thermostat will still hold some coolant in the engine so you need to undo other hoses too.
golfvr6
« Reply #11 on: 23 November 2003, 18:17 »
Yep exactly.
Offline mk28vpb91
« Reply #12 on: 23 November 2003, 20:23 »
Which hoses did you take off?
Started with the bottom hose, then the top hose, then removed the hose on the right hand side of the cylinder head.
When I flushed through from the cylinder head side all of the water came through the top hose (Haynes said it would come out the bottom) so I guess that would mean that the thermostat was closed.
Not too worried as I have got a lot more antifreeze in the system than there was before. I'm guessing that the heater held on to a few litres.
golfvr6
« Reply #13 on: 23 November 2003, 20:49 »
The rest of the coolant is stuck in the crankcase water ways. Removing the bypass hose/thermostat would let it out. You get an antifreeze tester from halfords for a few quid, so you can check the mix is ok.
