Author Topic: Mk1 Brake pedal  (Read 1903 times)
Offline sbsshadow
Mk1 Brake pedal
« on: 02 March 2006, 19:36 »
Hi All
I have a 1990 mk1 cabriolet and the brake lights wont go off after you have pressed the pedal
unless you put your foot under it and lift it up.
Does anybody have any ideas to get rid of this problem ??
Thanks
Steve
Offline Tucker
Re: Mk1 Brake pedal
« Reply #1 on: 02 March 2006, 21:22 »
Get your head under and av a look :laugh:
Should be a switch on top of the pedal, check its not moving about and adjust if needs be :wink:
Tucker
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline mk1
Re: Mk1 Brake pedal
« Reply #2 on: 02 March 2006, 22:42 »
No switch on the pedal on a mk1, check the mechamism between the pedal and the master cylinder, poss a siezed pivot on the "x" linkage.
Steve.
Offline sbsshadow
Re: Mk1 Brake pedal
« Reply #3 on: 03 March 2006, 09:04 »
Thanks
I will av a butchers ..............
S
