Author Topic: Smoky 8v-is it a problem??  (Read 2496 times)
Offline 15 inches
« on: 20 November 2003, 12:19 »
I was going to swap an 8v engine with good box and power,into my mk2 to replace my engine which needs new box and the power-150k.
Prob is that new 130k engine smokes a bit when you drive it hard-125mph hard!
Does a smokey engine mean trouble?????
My original engine has had new cam belt and been set up,ect ,ect.The new engine i have no history of.
Smokey engine used to mean stay away in my day!!
But it only does this when driven naughtily ;D
Was just going to swap box and power-but this way could be easyer
Any advice much appreciated
Offline Leejaydoob
Re:Smoky 8v-is it a problem??
« Reply #1 on: 20 November 2003, 12:56 »
a mate of mine had a 180000 mile passat with a similar prob to yours. he used 'Greased Lightning'
ptfe engine treatment and it worked wonders
gave the engine a new lease of life and no more smoke
www.greasedlightning.com
might be worth a try if your engine is tired
golfvr6
« Reply #2 on: 21 November 2003, 13:33 »
Get the engine rebuilt before you put it in. Will last another 150k.
turbo
« Reply #3 on: 30 November 2003, 00:42 »
could be either the valve stem seals or worn piston rings, get a compresion tester and check the compresion of each cylinder if there ok it may be your valve stem seals......
valvoline maxlife oil will help! i use this myself and my mk 2 is on 194000!
