Golf mk4
Golf mk4 how to guides + info
Wazzzer
OBD, VAGCOM, Fault Codes. What they mean and probable causes.
4
5
Topic: OBD, VAGCOM, Fault Codes. What they mean and probable causes. (Read 206201 times)
richandhazel
Global Moderator
Forum addict
Re: OBD, VAGCOM, Fault Codes. What they mean and probable causes.
Reply #20 on:
12 February 2007, 22:55 »
Can't find that code. What vehicle is it? I tried a search under 2000 1.8T Golf and it didn't come up.
Can you give me some more info, P code etc.?
richandhazel
Global Moderator
Forum addict
Reply #21 on:
12 February 2007, 23:01 »
Ah, just found this:-
00287 - Wheel speed sensor, right rear
I'll see if I can dig out some tests.
richandhazel
Global Moderator
Forum addict
Reply #22 on:
12 February 2007, 23:06 »
Does this help:-
http://homepage.ntlworld.com/richandhazel1/abs
DazVR6
mk3 VR6...FEEL THE GRUNT.
Reply #23 on:
13 February 2007, 00:22 »
sorry should of said its for a mk3 97 16v....
richandhazel
Global Moderator
Forum addict
Reply #24 on:
13 February 2007, 10:04 »
Try the tests that I have uploaded above. I'm pretty sure it'll be the same for your model, I'll just double check.
richandhazel
Global Moderator
Forum addict
Reply #25 on:
13 February 2007, 10:19 »
Not sure if they are any different, quite possible with one being a mk3 and the other a mk4.
I have now uploaded the correct tests for your model:-
http://homepage.ntlworld.com/richandhazel1/abs16v
DazVR6
Reply #26 on:
14 February 2007, 00:29 »
Cheers..
S7CYW
GTI forum regular
DUB
Reply #27 on:
14 April 2007, 12:21 »
I've got fault code P1200, regarding the wastegate. (2001 mk4 AUM 1.8T )
Can't find the code in the list, seems to be missing
kells
Guest
Reply #28 on:
01 November 2007, 22:34 »
mk 3 GTI 8v 1993
00518 Throttle pos sensor
34-10- no elaberation available - intermittant
what does all this mean?
gazbutmk5gti
Reply #29 on:
22 February 2008, 10:54 »
Hello
Got an airbag fault on dashboard and the following fault code through diagnostics any ideas?
04C6 crash sensor side airbag passenger side G180
On a mk4 golf 4motion 2000
cheers
Revo stg2+ & lots more
4
5
Golf mk4
Wazzzer
