Author Topic: Not another leak!  (Read 3646 times)
Offline GemGTI
  • Gemma
Re: Not another leak!
« Reply #10 on: 12 March 2006, 21:05 »
Latest update on leak... peeled back carpet on drivers side and the floor is soaking wet under the sound proofing. It is dry in the back which seems strange to me as this is where the carpet ends up soaked. Does this mean its coming in at the front and travelling back? How do I dry out the floor and stop the leak for good?
Cheers, Gem
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #11 on: 12 March 2006, 21:13 »
I would really consider taking out your carpet completely and two front seats and then close the doors and put the water using a hose over the sunroof and through the door shuts and over front screen - see if water is coming in from those area's and if not then its got to be coming in from engine area - check for any holes near engine area that will allow water in, also check the shuttle area where the heater unit is - water somethings comes in there if water is not draining properly in the shuttle area.
Might want to leave your carpet out for a while to allow water to dry up as well.
Also - I noticed that you park your car on the drive way facing your house, which is slightly on a angle - so any water that sits in the engine area of shuttle will if there are any gaps or holes, go straight into the car - try parking the car facing the road - see if your leak stops - if so its more than lucky shuttle or engine hole somewhere.
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline Phil303
« Reply #12 on: 12 March 2006, 21:15 »
It may not have dried out from last time? The only thing I can think of is to take the carpet up and get some air on it? I still blame the scuttle...  :grin:
Unless you have a massive hole in the floorpan I doubt that water is working it's way in from underneath. When I had the same problem I thought that maybe water was coming off the road, but I was told that it is very unusual and highly unlikely that that amount of water can work it's way up.
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #13 on: 15 March 2006, 21:41 »
I got to seal my scutle are on my mk1 also, i got some great stuff for my mk2, it was guttering sealant, it was black, really sticky and was very water tight, but the mk1 is white! any ideas on what's the best sealant type stuff to use?
Also, the major leak i had on my MK1 was coming from the passenge side, where the arial cable can through, but i ain't got any inner wheel archs on mine (as it's an import) but maybe worth a check!
Offline Phil303
« Reply #14 on: 15 March 2006, 23:04 »
Two great products to seal the scuttle with:
Stonechip - get it from Wilco or Halfords
Schutz - if you can't find it in your local car-care emporium, Jaguar dealers stock it.
Both can be sprayed when dry. Used on mine and the leaks stopped.
Offline Deefadog
« Reply #15 on: 16 March 2006, 07:40 »
Thanks phil!
Is that Stonechip stuff like a slicone? and does it come in white? :)
Offline Phil303
« Reply #16 on: 16 March 2006, 16:48 »
More like a sealing paint rather than silicone.
I think it's black but it can be painted when dry.
Offline Deefadog
« Reply #17 on: 16 March 2006, 20:27 »
Thnaks, i'll pop down on the weekend :)
Offline me
« Reply #18 on: 29 March 2006, 00:22 »
don't know if this helps but i had tons of leaks in my last mk1.
the water would come down the doors and out the bottom of the split membrane also where the prev owner installed an alarm no gromets were used so water was trackin down wires. but the main one was with my sunroof (dont know if u have 1) the drain pipes had split at the joints so water was just running down the door pillars good way to check if its runnin down them is to pull your seatbelt out all the way and feel if the cord is wet hope this helps.
Offline GemGTI
  • Gemma
« Reply #19 on: 29 March 2006, 22:50 »
Thanks, this is really doing my head in. I checked the sunroof drainage holes by putting some wire down them. They seem clear, a bit of dirt came out with the wire but it went through easy enough. I've checked the scuttle and can't see any holes at all and the drainage holes are clear. I thought somehow it could be coming in through the rubber boot round the steering column as sometimes when I drive up a hill water drips onto my feet. I've been told It won't be this. I want to re carpet my car but can't until I find this F**king leak!!! :angry: I will check out the seat belt idea thanks  :smiley:
