Author Topic: Help? - MK4 GTI 20V 1.8 (non turbo)  (Read 9013 times)
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re:Help? - MK4 GTI 20V 1.8 (non turbo)
« Reply #10 on: 01 December 2003, 19:54 »
I had my PD150 go back to the dealers two weeks after I picked it up when I had water collecting in the passenger and rear footwells.
It turns out that I had a kinked air conditioning vent pipe, and condenstaion was building up and not being able to vent to atmosphere. This meant that the water was running back down into the car.
As well as checking out your rear wash wipe (as this is common fault) get your heating/vebtilaion/air con checked too.
Welcome to the wondeful world of Mk4's!
The greatest leveller of them all - the Carousel
kniterider
« Reply #11 on: 02 December 2003, 14:19 »
yep and yas dont want any moisture in the car this time of year as its steamy windows season!! lol my mk2 is a right steamer
Offline mak911s
« Reply #12 on: 09 December 2003, 12:14 »
cheers kniterider
think you've sussed this problem spot on.  Followed chris's
http://myweb.tiscali.co.uk/golfstuff/rear_screen_washer_repair.htm
repair guide and all ok in the washer end connection area.
That said, in testing to see if connector dodgy, squirt, squirt, squirting away as you do, noticed small damp patch on the rear passeger 1/4 side roof lining.
Opened the First aid /cd changer compartment and leak found.  Squirted a bit more and true enough, major leak, but not sure if this a diy repair.
The area where leak appears to be coming from is from behind the vertical passenger rear 1/4 pillar. Section looks to be separate from main roof headlining and may just lift out, after many slicing of digits getting trim out of way first.  Hopefully theres asmall burst pipe hehind, ie easy repair.
Any suggestions.  Will have a go probably this weekend.
cheers
Mark
ps,  sorry for impatience on the audio forum.  Think i had a few stellas too many when i posted that one.
