Author Topic: DIY fitment guides for genuine VAG cruise control  (Read 21846 times)
Offline boyob32
  • 1.8T
Re: DIY fitment guides for genuine VAG cruise control
« Reply #10 on: 03 June 2007, 20:23 »
Any body know the anser to the above??
I am interested in trying this out,  i have a 1999 2.0 gti....
Offline richandhazel
« Reply #11 on: 04 June 2007, 09:56 »
The mod shown here can only work with a drive by wire system. I can't see any way that it could work with out the electronic throttle box.
Mine is 1999 and drive by wire. Do they still produce non drive by wire after 1999?
Offline Immortal
  • 1.8 Turbo GTI (AUM)
« Reply #12 on: 17 June 2007, 02:36 »
Does anyone have an additional loom to fit to a 1.8T? The link on golfmk4.co.uk doesn't work any more :cry:
« Reply #13 on: 17 June 2007, 16:52 »
Just checked, you're right, damn. I think you can buy them from ebay.
Not sure, but the part numbers may work at you local stealership :undecided: Don't see why they wouldn't as they are part of the oem.
Offline Immortal
« Reply #14 on: 23 June 2007, 00:20 »
You can now get the additional loom required to fit cruise control to a 1.8t (and other models) as a genuine VW spare.
 For engines with the 80-pole ECU plug (Engine codes: APE, AXP & BCA)
1J0.971.425.B
For engines with the 121-pole ECU plug (Engine Codes: ARZ, ATN, AUM, AUQ, AUS, AZD, AZH, AZJ, BAD, BCB, BFQ)
1J0.971.425.C
The wiring goes as follows:
Engine Code: APE, AXP & BCA (80-pole plug)
Pin 24: Black/White Wire
Pin 25: Red/Yellow Wire
Pin 39: Blue/Grey Wire
Pin 50: White Wire
Engine Code: BAD (121-pole plug)
Pin 49: Blue/Grey
Pin 51: Red/Yellow
Pin 52: White
Pin 55: Black/White
Engine Code: BFQ (121-pole plug)
Pin 66: Red/Yellow
Pin 67: Blue/Grey
Pin 68: White
Pin 69: Black/White
Engine Code: ARZ, ATN, AUM, AUQ, AUS, AZD, AZH, AZJ & BCB (121-pole plug)
Pin 38: Black/White
Pin 57: Red/Yellow
Pin 75: Blue/Grey
Pin 76: White
Hope this helps
Offline rs_dude
« Reply #15 on: 15 September 2011, 12:56 »
The websites are no longer there.  Does anyone know of a current website?
