Author Topic: ummm, roof bits?  (Read 1810 times)
Re: ummm, roof bits?
« Reply #10 on: 25 January 2006, 15:20 »
The black roof lining is only available for models with a sunroof, so if you don't have one you're out of luck :(
Headlining is held on with clips and all the interior trim, handles, sunvisors etc.  Its also glued on arround the runroof opening, some care is needed here to make sure you dont rip it whilst you remove/refit.
One thing to remember, is the 3 door B pillar trims (behind the doors) are held in with clips, once the seatbelts & levers are removed push the trim UP towards the ceiling to release it :)
The C pillar trims are clipped to the car and just pull off, as is the trim along the roof by the tailgate.  You'll need to remove the parcel shelfs to get the c pillars off, which is a good plan cos then you can replace em with black GTI shelves at the same time :)  While you're there get the boot side carpets as well, it cleans up the boot no end with em fitted!
Edit:  If you are planning to fit one, I'd remove the old one first before you go to collect the replacement, its VERY fragile once out of the car!  Theres a 3 door MK2s with the black headlining in my local scrappy down in Wokingham, but you'll need to come and get it :)
« Last Edit: 25 January 2006, 15:24 by rubjonny »
Offline steviem
« Reply #11 on: 25 January 2006, 20:33 »
I say you're a cheapskate for not getting a GTI  :laugh: but its a difficult job, well, my mates beetle headlining was hell.
Offline Haribo!
« Reply #12 on: 25 January 2006, 20:38 »
if i could find a GTI as mint as my driver than i would get one, but i dont believe there is such a thing
« Reply #13 on: 25 January 2006, 23:30 »
there are lots about, but you have to be patient and be prepared to pay a premium.  Either that do what I did and buy a banger for cheap & spend 8 months trying to fix it  :grin:
Offline Haribo!
« Reply #14 on: 26 January 2006, 00:46 »
uh yeah, if you spend 8 months trying to fix a car just imagine how long it would take me!!!! i`ll be patient but i quite like my car at the moment, i forgot how much fun driveing was when you dont have to sit with an idle or 4000 which looks and sounds very embarasing, plus its hard to drive when letting go of the brake makes you speed up, so now its all fine (and faster, not to mention smoother than when i had that weber) it may be worth keeping it, theres no hurry after all
