Author Topic: HELP NEEDED URGENTLY  (Read 3066 times)
Offline wickedweed
Re: HELP NEEDED URGENTLY
« Reply #10 on: 25 January 2006, 12:07 »
or will it take some cutting and joining  :undecided:
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #11 on: 25 January 2006, 12:08 »
Its probably either the switch on the steering column to put the full beams on (most likely) or the main light switch on the dash.  :nerd:
I've had this problem a few times over the years and its always come back to one of these, you can take the steering column one off and give the copper terminals a good clean and check them for damage but if its the main switch you'll need a replacement - they're not too much, about £15-£20  :smug:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline wickedweed
« Reply #12 on: 25 January 2006, 12:13 »
yeah thats what i was thinking but i have changed them over from another mk1 which i no works and its still the same..........? :undecided:
« Reply #13 on: 25 January 2006, 12:16 »
oh bugger   :huh: what about the relay?
my dub project:-
Offline wickedweed
« Reply #14 on: 25 January 2006, 12:17 »
and that still the same,
« Reply #15 on: 25 January 2006, 12:29 »
Have you got a bulb/circuit/voltage tester?
heres a highly technical drawing of the terminal, check your getting power from all the terminals, i cant remember which way round they are but the two +'s are for the main & dipped beams with the other being a common ground - all you can really do now is start there and work back til you find it and hope you dont end up at the fusebox, car electrics are a real pain in the rr's
my dub project:-
Offline wickedweed
« Reply #16 on: 25 January 2006, 16:15 »
yeah i think your right il give it a go cheers m8 :smiley:
