Author Topic: mk4 temperature display  (Read 3910 times)
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: mk4 temperature display
« Reply #10 on: 22 January 2006, 21:22 »
VAG = Volkswagen Audi Group
Nah not a specialist job, took mine off myself, its just too hard to explain on here, and you dont want to fudge it up, if you do fancy it tho:
Turn the wheel 90 degrees from being straight. You will see or feel a hole behind the wheel where it rotates from the steering column. Take a long flat head screwdriver, put it in the hole the open the clip. You need to undo the clip by pulling down on the screwdriver like opening a tin of paint. then try to clip it back in properly. Good luck, if you have a go
« Last Edit: 22 January 2006, 21:35 by GazB »
Offline nadlad
  • Building Surveyor MRICS
« Reply #11 on: 22 January 2006, 21:33 »
yeah ill take it main dealers get the airbag thing sorted and the rear window demister the button seems to be stuck in do all the tdi se mk4 golfs coem with heated wingmirrors as standard i think my right one does not demist
also how do u take the rear lights off got a pair of gti lights 40 quid genuine wanted to put them on
<<<Big Build Thread>>>
Offline GazB
« Reply #12 on: 22 January 2006, 21:46 »
Window button is prob fecked, a new one will be £20-£25 and as for the rear light, what a complete bastid of a job :angry:
Offline nadlad
« Reply #13 on: 22 January 2006, 21:55 »
gazb, does the rear window demister button cover the wing mirror demisitrs ....
if u dont mind me askign why is the rear lights a bastrd of a job to do i thought it wud be a simple plug n play job or is it more than that
