Author Topic: **How do you remove this stuff??**  (Read 3838 times)
Offline JMallows
Re: **How do you remove this stuff??**
« Reply #10 on: 21 January 2006, 22:14 »
T-Cut should do it, or maybe wax polish? + Elbow grease ;) Failing that, i can almost certainly gurantee that autoglym tar remover will do the job!
thats like the way that runs out the back off the boots corners, i find autglym polish usually gets it off!! maybe a good polish will help remove sticky? but i'd go with blue./ he's generally right.... c*cky lil....
Incidentally, the stuff coming out the back is the waxoyl stuff from the inside as it heats up and just starts to melt.
A clever person solves a problem. A wise person avoids it.
Offline baz_the_man62
« Reply #11 on: 22 January 2006, 15:52 »
ill tell u what, for a tenner, you can buy a toffee/caramel wheel, its made of rubber, you put it in a drill and use the spinning edge which will roll any sticky strips or car stickers off without marking your paint.
u can pic them up at car paint shops etc
Offline golf gti 16valve
« Reply #12 on: 23 January 2006, 01:51 »
yea thats a thought,they use them at work,didnt know if it damaged the paint though,ill get onw tomoz! cheers ppl!  :grin:
