Author Topic: Starting/running problems poss fuel supply  (Read 2357 times)
Offline takethefifth
Re: Starting/running problems poss fuel supply
« Reply #10 on: 20 January 2006, 16:02 »
He's right......   but if you do want to check it you need a multimeter and the chart (Fig 7-7) on this link - http://volkswagen.msk.ru/vw_doc/eva2/FU01/ch7.2.1.html
The biggest problem is guestimating the temp of the coolant, easiest is to get the resistance, cross reference it against the chart and see if it looks like a realistic temp for your coolant to be. My ohm reading was 96000, considering the chart only goes up to 7000 i guessed something was wrong!  :laugh:
Or stick a thermometer in your coolant bottle?!  :wink:
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
« Reply #11 on: 22 January 2006, 11:52 »
anyone got the part number for this blue sensor for the kjet 16v cos my vw centre reckon they don't know which sensor it is.  there bloody useless they even said the weighted shift rod off a mk3 wont go straight on a mk2 without major modification lol.  nobheads but i need a number so if anyone can help ill be happy cheere
« Reply #12 on: 22 January 2006, 12:09 »
There isn't one for a 16v, only the digifants have em :)
The 16v does have 3 identical sensors in the right side of the head for the temp gauge, wur and 5th injector I think?
Offline marcogolfo
« Reply #13 on: 22 January 2006, 17:17 »
any idea what the part number is for them sensors?  cheers
« Reply #14 on: 22 January 2006, 17:34 »
I think the one you need is 049 919 501, its a single pin black one :)
Offline marcogolfo
« Reply #15 on: 22 January 2006, 19:06 »
thx
Offline Steve_B
« Reply #16 on: 26 January 2006, 11:00 »
Just got a new airflow meter through the post today, will be fitting it at lunchtime. Looks pretty straightforward but just wanted to ask if anyone knows of things to look out for when doing it. Any tips gratefully received.
« Reply #17 on: 26 January 2006, 13:17 »
dead simple, remove the vacuum pipes on the side, undo the clips, and unscrew the jubilee clip holding the intake pipe on.  Wiggle it out, then the AFM is held to the airbox with 4 bolts.  Don't loose the o'ring, and refitting is the reverse of removal.
Obviuosly you'll need to re-setup the idle & CO after:
http://www.golfgtiforum.co.uk/index.php?topic=33253.0
Offline Steve_B
« Reply #18 on: 31 January 2006, 16:44 »
Atfer fitting a new airflow meter, found out it was the temp sender after all. So I now have a spare airflow meter after the garage got the problem wrong (glad they didn't get my money!). Does anyone know how to see if an airflow meter is working properly, and also where to get VAG blue and black temp senders. I'm guessing VW but they're usually expensive.
Offline Brads MK2 GTI
« Reply #19 on: 31 January 2006, 16:57 »
Yes matey get your blue temp sensor from VW (think it's about £13). I can't get you the part number, I don't have ETKA on this machine, but I'm sure someone will have it. You can buy a copy sensor from GSF, but don't, it's crap and will fail.
