Author Topic: Creamy Sludge???  (Read 2723 times)
Offline golf gti 16valve
Creamy Sludge???
« on: 12 January 2006, 16:22 »
Hi ppl, i removed my engine breather pipe from my airbox and noticed a load of creamy stuff in it, when water mixes with oil!, its only in the breather pipe,so i dont think its a head gaket, the water never needs topping up, theres no white smoke, the engine runs fine from cold, theres no sludge under the oil cap, and when i shine a torch into the block where the breather pipe goes theres no evidence of it in their either, Just in the breather pipe and in the airbox,looks like its been sucked into airbox, i do have a KnN panel filter and drilled air box.
im thinking its just where the pipes old,and when you start up from cold the pipe is cold, so condensation forms in it?
Any suggestions?? Thanks
Tom
Offline Si
Re: Creamy Sludge???
« Reply #1 on: 12 January 2006, 16:24 »
I got creamy sludge under my oil cap. Nothing to worry about i dont think.  :wink:
This is where someone tells me my engine is about to go boom?!!  :laugh:
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline pinkcrush
« Reply #2 on: 12 January 2006, 16:28 »
i had that once on a orion, it was the head gasket :(
good luck :)
Offline Maltloaf
« Reply #3 on: 12 January 2006, 16:30 »
You sometimes get that this time of year if you do a lot of short journeys. Try running it up to temperature and go up and down the motorway a junction or so. it might clear it up.
Offline Veedub1989
« Reply #4 on: 12 January 2006, 16:33 »
under oil cap normally means headgasket  :cry:. get a compression test sorted sharpish.
the white sludge in your breather (and no where else) is most likely formed due to condensation building up as the engine isnt getting hot enough for long enough for it to be evaporated... i guess you're using your mk2 only on short journeys? this is most likely the case. just wash it out with WD40 or i found using a rag stuffed in there with a screw driver worked the best. as long as you havent got any under your cap you're fine mate  :wink:
VW Golf 1989 2.0L 16v
Offline Si
« Reply #5 on: 12 January 2006, 16:33 »
good luck :)
Yeah but that was a Ford!  :laugh:
Offline Si
« Reply #6 on: 12 January 2006, 16:34 »
Thats only water bottle i thought?
Offline Maltloaf
« Reply #7 on: 12 January 2006, 16:36 »
I would have thought if water mixes with oil it will produce creaming any where it can condense?
« Reply #8 on: 12 January 2006, 16:38 »
Nowt to worry about both mine & Jame_S gets loads of sludge in the breathers, if its under the cap it can be slightly more worrying.
Si: Since your engine is running too cool I recon this is the cause of the condensation under the cap, its even less likley to get up to a high enough temp to burn off all the condensation, so even more sludge :)
Offline Si
« Reply #9 on: 12 January 2006, 16:40 »
Thank god for that!
