Golf mk2
Driver brakes
Topic: Driver brakes (Read 1469 times)
Si
Driver brakes
12 January 2006, 15:42 »
Are the Brakes on a 1.6 Driver supposed to be same as GTI?
i.e. are the disks supposed to be vented or solid? if solid, then the caliper is different isnt it?
I know the Drivers have drum brakes on rear.
I LOVE THE SOUND OF CARBS IN THE MORNING
Rhyso
Global Moderator
Sir Postalot
Re: Driver brakes
12 January 2006, 15:52 »
same size as the 8V gti aren't they?? the difference being the pads and discs are different widths;
can't remember if the pads are thicker and discs thinner or the other way about
Fire Up The Quattro
Si
Re: Driver brakes
12 January 2006, 15:54 »
So you mean the Driver has narrower disks (solid) and thicker pads, and GTI has wider disks (vented) and narrower pads?
Rhyso
Global Moderator
Sir Postalot
Re: Driver brakes
12 January 2006, 16:04 »
urm pass I'm afraid. i'm just going on what I've read somewhere on the forum before
Fire Up The Quattro
Rhyso
Global Moderator
Sir Postalot
Re: Driver brakes
12 January 2006, 16:16 »
here you go si
http://www.golfgtiforum.co.uk/index.php?topic=23287.0
have a read of that
Fire Up The Quattro
Si
Re: Driver brakes
12 January 2006, 16:20 »
Thats what i thought... cheers very much chap!
VWDino
GTI forum regular
MkII 1.6 Driver. GTi cam, K&N .....
Re: Driver brakes
Reply #6 on:
12 January 2006, 16:56 »
Yep, swapped them myself. Zimmerman disks and Pagid Fast Road pads from GSF.
Golf mk2
Driver brakes
