Author Topic: doing the engine up  (Read 2232 times)
Offline theviper
doing the engine up
« on: 09 January 2006, 08:32 »
i want to so doing the eninge up after i have finished my sounds but dont want to change the engine and that will not cost loads all i can think is
1 Cam
2 Air filter
3 HT Lead (4 core i belive there are doing now)
4 plugs to go with the leads
5 not sure of the name but to pushes the fuel run to the carb it is like FPS so somethink like that
i am blank after that any help
Pete :evil:
Offline Daz...
Re: doing the engine up
« Reply #1 on: 09 January 2006, 09:14 »
what engine is it pete? im guessing its not a gti seeing as you mentioned a carb in there..
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Offline theviper
« Reply #2 on: 09 January 2006, 10:49 »
it is a 1991 1.6 driver was fitted with a cat but have removed it  :smiley:
Pete  :evil:
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 09 January 2006, 17:17 »
a Fuel pressure regulator ups the pressure the fuel goes in, but not sure if you can do that with a carb.
Putting 'high performance' leads on won't make any difference to the performance, but they look nice in blue :D
Apparently the gti cam is a simple, but effective upgrade to the driver engine.
a free flowing filter will free up 0.5 bhp :D
Mk4 Golf 150PD
Offline theviper
« Reply #4 on: 09 January 2006, 19:46 »
WOW a whole 0.5 BHP i best get the touch out and do it now  :grin: :grin: :grin:  anyway what is free flowing filter ??? so all i can do really is a cam from the GTI. will be getting that next week then roughly what will i gain ??? 5-6 BHP
Pete :evil:
Offline Gambit
« Reply #5 on: 09 January 2006, 19:56 »
get the 8v GTI manifold exhaust also
Offline theviper
« Reply #6 on: 09 January 2006, 20:23 »
will the manifold go straight on ??? what about the rest of the exhaust ???
Offline Gambit
« Reply #7 on: 09 January 2006, 20:31 »
yes it will fit straight on.
not sure if the driver exhaust bore is smaller or not than the 8v GTI - someone else should be able to confirm
Offline ...joe
« Reply #8 on: 09 January 2006, 21:01 »
don't think the driver exhaust will fit the manifold but i'f you're gonna put a gti manifold on you might as well put on the rest of a gti system....
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Brads MK2 GTI
« Reply #9 on: 10 January 2006, 10:11 »
Take a look at getting a webber carb to replace the crappy pierburg one. The webber if set up right should give you a nice boost. Either that or the the bolt on K & N filter might be alright. I think there's a webber on ebay at the moment, might be worth a look. The cam would be a good place to start as mentioned earlier.
Strangely enough, I never really bothered doing any engine mods to my driver when I had it, but then it had done over 215,000 and had a crack in the head! Ha I can remember the tank now!!
