Author Topic: what size rad???  (Read 2893 times)
Offline rowlers
  • I'm back - MK7 GTI
Re: what size rad???
« Reply #10 on: 18 January 2006, 17:14 »
----->>> see the rubjonny tribute!!:grin: :grin: :grin:>
what about airlocks?? any technique involved??
Offline ...joe
« Reply #11 on: 18 January 2006, 18:00 »
run the car with the expansion cap off and let it get up to temperature, this should work out all the air bubbles. helps to have the heater slid all the way to red as well.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline rowlers
« Reply #12 on: 18 January 2006, 18:13 »
tribute to ...joe????
« Reply #13 on: 18 January 2006, 18:17 »
This is the method I use:
Run the engine from cold with the cap off and rev it to 2k now and again.  While you are doing this squeeze all the pipes you can get your hands on, and keep the coolant level topped up.  It will eventually start to boil over, at this point turn the engine off.  Once its settled down top it up to the max mark and you should be good to go!
Even then sometimes the only way to get rid of persistant airlocks is to give it a good thrash :)
No need to switch the heaters to hot on a MK2 as the coolant is always flowing round the matrix regardless.  Its good practice to do it anyway, especially if you arn't sure if coolant flow is blocked by the heater controls or not.  The MK1 needs the heaters setting to hot :)
Offline rowlers
« Reply #14 on: 23 January 2006, 20:11 »
Can someone point to the temp sender on thie piccies below:::
I have a feeling that I have something missing???
See post below of whats need to convert to a 2 speed fan as said by the legend that is rubjonny!
edit::
forget that-  it is plan to see in the bottom of the rad!!! :embarassed:
« Last Edit: 23 January 2006, 21:07 by rowlers »
« Reply #15 on: 24 January 2006, 10:31 »
Get some new glasses :grin:
Offline rowlers
« Reply #16 on: 24 January 2006, 18:07 »
on there way!! :grin: :grin:
Offline rowlers
« Reply #17 on: 29 January 2006, 17:11 »
well its done got it fitted this morning all is OK, also seems to be running a little cooler (and smoother????) will let you know how it goes!
Onlt one problem though
the arrow points to a single connecter that doesn't seem to go anywhere?? there wasn't one on my old fan???
any ideas??
the fan does work, comes in just after the half way mark.
« Reply #18 on: 29 January 2006, 18:40 »
Ah I think that runs from the after run sensor that some GTIs have, the sensor is usually near the zaust or inlet somewhere and can turn the fan on when the car is off.  No need to worry about it :)
Offline rowlers
« Reply #19 on: 29 January 2006, 19:03 »
spot on cheers fella, my old fan did use to run after car turned off?
