Author Topic: Daft Question Time: Is A Mk2 Golf Glove Box Removable?  (Read 6593 times)
Offline mookie
  • Geordie ABF!
I want to run the lead for a Kenwood iPod adapter unit from the back of the headunit into the glove compartment, but I don't fancy dremmelling a hole through the top of the glove compartment with it inplace. I've had a look and it appears to be held in place with a load of screws, but don't want to start pulling that thing out as I don't really know what's going to be hiding behind it. So, am I on  the right lines? Can I remove the box, dremmel a hole, and screw it back in? Will there be enough of a cavity behind the dash to run the lead down that far?
Any help at all would be greatly appreciated.
Offline [han]
  • Graphic Designer for Haribo
Re: Daft Question Time: Is A Mk2 Golf Glove Box Removable?
« Reply #1 on: 05 January 2006, 22:12 »
it is, cos i got an imobiliser switch behind mine, but i dunno how to get it out...
why for do you need ot run it into glovebox? can't you bring it out in centre console?
Offline mookie
  • Geordie ABF!
« Reply #2 on: 05 January 2006, 22:26 »
I dunno I just thought it was the perfect place to hide away the dinky little square control box and also so my iPod is out of sight. Also I didn't fancy pulling out the centre console  :cry:
Offline GolfChick24
« Reply #3 on: 05 January 2006, 23:42 »
leave it and run or manage without taking it out!!!! run away from the light!!!
Offline GolfChick24
« Reply #4 on: 05 January 2006, 23:43 »
they are very difficult to remove, i tried once and was prewarned to how hard they are. my corssovers are installed in it and i managed to do it while it was still attached.
Offline Lewy
« Reply #5 on: 05 January 2006, 23:46 »
Tis true, pain in th'arse, try running it through the bottom of the centre console as there is loads of room there.
Offline diagnosis-dub
« Reply #6 on: 06 January 2006, 01:14 »
The easiest way is to remove the two hinge pins by sliding them out and remove the lid from the backing shell, then just go round and unscrew this without the lid getting in the way of the screws.
Offline mookie
  • Geordie ABF!
« Reply #7 on: 06 January 2006, 01:31 »
So the general consensus is that this plan of mine is a total nightmare? Awesome.
The stupid thing is I got the full Kenwood iPod package for Christmas off my girlfriend. New headunit and whatnot. And she offered to pay for it to be professionally installed. "Nah, piece of cake" I said, in a manly voice. f**k me, what a tool I am sometimes...  :rolleyes:
« Reply #8 on: 07 January 2006, 00:18 »
The glovebox is easy to remove and is no hassle at all, only involves removing screws. Can't get easier then that.
Offline Ozz
« Reply #9 on: 07 January 2006, 00:22 »
I'd choose to have it in the centre console, as its more easily accesible when driving, and the centre console is easy to get out. It's only held in by 3 screws, then pulls out backwards (easiest if you knock it into 2nd). Plus its quite a deep space so is generally out of view if you tuck anything right down in to it.
Mk2 Gti 8v
