Author Topic: Starting problems - just checking....  (Read 2884 times)
Re: Starting problems - just checking....
« Reply #10 on: 05 January 2006, 22:20 »
Its 025 906 041 A :)
Offline takethefifth
« Reply #11 on: 07 January 2006, 01:43 »
Right finally job done. Swapped the sensor today and its all running sweet as a nut again.  :cool: With the new coil, leads, sparks, oil and filter i would even say better!
Had a bit of a nightmare though, after an hour of trying to figure out why the sensor wouldn't seal the water in anymore I had to thank rubjonny who confirmed that there should have been a rubber o ring in there.... DUH.  In my attempt to change it without draining the coolant the water pushed out the o ring when i took the sensor out. I so concerned with all the water coming out i didn't notice the o ring jump out and lodge itself behind the distributor.  :grin: Cheers Jonny!
So morals of the story -1.  I don't trust GSF temp sensors (VAG one was 9.52+Vat) and 2. Don't lose the o ring!
Offline ANDY597
« Reply #12 on: 07 January 2006, 09:34 »
Check out my previous post, exactly the same issue thats going on here.
http://www.golfgtiforum.co.uk/index.php?topic=32086.10
I think these GSF blue senders are the route of the problem,  my car has never ran so bad. Fitted the GSF just before christmas.
Have also discoverd that its started leaking this morning, and its not just a dribble.  It cant be helping matters that all that moisture is kicking about my bits.
Called the stealership last week and they said it was in stock,  so went straight down there to pick one up but they said they hadnt had one of them for ages.  I was furious.
Its been ordered and it due in today,   the missus is going to pick it up, so I hope she remembers the new rubber O-ring that goes with it.
Offline ANDY597
« Reply #13 on: 08 January 2006, 14:39 »
Fitted the new blue sender today,  vag part.
Car started first turn of the key and ran, sweet as a nut.
Now noticed the black Gsf temp sender that controls the temp gauge is now leaking too.  You guessed it,  from Gsf that I fitted at the same time as the last blue one.
GSF are now off my christmas card list.
A
« Reply #14 on: 08 January 2006, 14:45 »
 :laugh: and mine!  :grin:
Offline 1985sport
« Reply #15 on: 11 January 2006, 22:28 »
which switch is this one? - i.e. where is it located?
ive been trying to think when my "warm starting" problem started and it was around the time i changed my radiator and the little thermoswitch at the bottom (although i thought that this was for the fan).
Re: http://www.golfgtiforum.co.uk/index.php?topic=32190.0
thanks,
1985sport
It's cool to be square
1985 80 Sport - 1781cc 8v
1986 Coupe Quattro - 2226cc 10v
« Reply #16 on: 11 January 2006, 22:40 »
The little thermoswitch on the bottom of the radiator is the fan.  For a digifant engine the one we changed is on the water inlet on the front of the block. There are two temp sensors next to each other. Black one for the dash reading and a blue one for the ecu and cold start functions.
Offline 1985sport
« Reply #17 on: 12 January 2006, 11:49 »
cheers tt5th. thats helped a lot actually as that area is all a mess!
nice car by the way - nice and standard body, just as we like it!
1985sport
