Author Topic: New, but old rimmage!!  (Read 2210 times)
Offline Lewy
Re: New, but old rimmage!!
« Reply #10 on: 22 December 2005, 18:58 »
And i need some fat smaller wheels - does 15x8 give you any rubbing problems? Are you running lowered suspension?
I was tempted by 16x9 but not happy about the arch work! Maybe 15x9..........  :smiley:
With your ride height in your sig, you should be fine!! :wink:
It's on coilovers but as the wheels are tyre-less I won't know until next month, but theres no engine in my mk2 so I won't know for a while. I don't anticipate any problems, as it was too low before on the 6.5x15", and I'm quite handy with an angle grinder!!
Offline takethefifth
« Reply #11 on: 22 December 2005, 19:08 »
Hahahaha! You aren't the first to mock and i'm sure won't be the last!  I am hoping smaller wheels first and then a drop.
Did a google for wider 15's and found nothing apart from references to Chevette rally wheels! Hmmmm....  I take it yours were widened for you? Or are they off the shelf like that?
Cheers!
Offline Lewy
« Reply #12 on: 22 December 2005, 19:14 »
I split them, had the centres powdercoated, and bought new wider outer rims which are widely available. Beware though, the outlay for these kind of rims is in the £1000 mark, they've cost me over £850 and thats without tyres.
Offline Agreeable Slick
  • Unit
« Reply #13 on: 22 December 2005, 23:57 »
wider rims regardless of diameter are going to foul the arches and will require work to get them to fit. Unless you space them out from the hub.
« Reply #14 on: 23 December 2005, 15:24 »
Pish, well if thats the score then wheels can wait till i have a new job!
MERRY XMAS!
 :santa:
