Author Topic: Stripped Headbolt  (Read 2074 times)
Re: Stripped Headbolt
« Reply #10 on: 12 December 2005, 15:04 »
Quote from: veedubgti16v
is it cast with the bottom end or interfeirence fit?
Sorry I don't know what you mean?
VeeDubGTI16v
« Reply #11 on: 12 December 2005, 15:24 »
hows the bolt attached to the bottom end? seperate part or part of the bottom end casting, ie if you heat up the surrounding metal could it be taken out :huh:
« Reply #12 on: 12 December 2005, 16:00 »
Oh I see!  The head bolts screw into a thread cast into the block!  Only way round it is to retap & use a larger thread really.  I don't think a helicoil would be strong enough!
Offline dubninja
« Reply #13 on: 12 December 2005, 22:08 »
Have been onto a local engineering company that do engine rebuilds and repairs, they recon they can pop a helicoil to repair the thread for £40 which doesnt sound bad.
I have to say that im a little unsure that it would be strong enough but they seem to think it will be fine.
« Reply #14 on: 12 December 2005, 23:07 »
Worth a go for £40!
Offline hc-animal
« Reply #15 on: 14 December 2005, 18:41 »
helicoil will be fine. on some hipo race motors with alloy blocks helicoils are used from new as they are stronger
Offline dubninja
« Reply #16 on: 24 December 2005, 21:53 »
Just to keep this thread upto date, i got the thread repaired, and all i can say is he did an awesome job on it. Dont think it was a helicoil that was used, looks like some sort of full thread insert, the heads gone back on today and they all torqued up fine, result! :smiley:
