Author Topic: Air filters??????  (Read 1977 times)
Offline Haribo!
Re: Air filters??????
« Reply #10 on: 10 December 2005, 03:12 »
it seems that i can get this at halfords :) great  :grin:
cheers for the help
Offline VWDino
  • MkII 1.6 Driver. GTi cam, K&N .....
« Reply #11 on: 10 December 2005, 14:50 »
Erm, you can definately get one. Theres one in my 1.6 Driver right now!  :smiley: If it helps I think the serial number is 33-2092.
Offline Neaty
« Reply #12 on: 10 December 2005, 15:22 »
^^ i guy i used to knock abot with had one on his 1.6 driver, so they are definately out there somwhere!
Offline Si
« Reply #13 on: 10 December 2005, 16:14 »
Haribo, i got mine from my mate at Hoopers Motorsport in Kingswood in Bristol.
Cant remember exactly how much it was but i recall it being about £40?!?
Ive taken mine off for the winter and stuck my standard airbox on.
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline baz_the_man62
« Reply #14 on: 10 December 2005, 19:48 »
i had a k&n bolt on for my 1.3 and according to the box it also did 1.6 carbs as well. cant remember the k&n number tho.
Offline [han]
  • Graphic Designer for Haribo
« Reply #15 on: 10 December 2005, 20:01 »
you can a green filter, and a k&n, and allsorts from motoro-world.. i been enquirirng about everything for mine! they do list it! if u still strugglin lemme know and i;ll get ya part numbers! ;)
Offline Haribo!
« Reply #16 on: 11 December 2005, 02:10 »
ah dont worry peeps, i found where i can get one all the way back on page one  :wink: :grin: , but when i went to hlfords today i found that a standard one was 5 quid and the K&N was 41 quid, so i said f**k that and got a standard one, they cant be 35 quid better, thats just silly.
ive got a Carb bolt on too which might fit my weber but i may have to make new holes... not sure yet, i really havent looked, i actually think ive broke my engine again,  its being clattery inside, no decrease in peformance just has trouble keeping at a steady idle, odd,
cheers
Offline gibby
« Reply #17 on: 11 December 2005, 10:05 »
I know what you are saying about the air filter but the k&n are good for 50,000 - 100,000 miles, so basically once you install them you never have to replace them on a service etc and can clean and re-use if you really want to, but with a stock filter you need to change it at every service, so in the long run the k&n isnt that much dearer but I guess at £35 difference you'd need to do about seven more services to break even.  :smiley:
For your clatter problem, check your oil level.  :undecided:
......now officially dubless.
Offline Haribo!
« Reply #18 on: 11 December 2005, 13:12 »
its about half way between the min and max, im not gonna lie, i thrash it everywhere i go so i guess i better keep it on the maximum  :huh: just to be sure
