Author Topic: Speedo noisy over 40mph  (Read 2610 times)
Judderi
Re: Speedo noisy over 40mph
« Reply #10 on: 30 November 2005, 09:05 »
probably cos its warmed up and freed itself. Wait till we have a big frost again.
Offline gti jim
  • return of the vac...
« Reply #11 on: 01 December 2005, 17:20 »
Its either the speedo cable or clocks frozen. I used to get this too. Id Replace the speedo cable 1st
It might also be the milage counter. When it does it see if your miles count away or stick.
i noticed that the needle on the speedo started wibbly wobbling a bit when it makes the whirring noise.  think i'll get myself a new speedo cable.  not a great problem considering it's 16 years old huh..
Offline Gambit
« Reply #12 on: 01 December 2005, 20:22 »
usually the noise is from the cable rubbing against something as it rotates. eventually the cable either wears out a notch in rubbing against. but if its rubbing against metal it'll be there for a long while!
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
« Reply #13 on: 02 December 2005, 00:10 »
 :smiley: my noise has been non existent for a few days lets hope thats the end of it!!  :shocked:
