Author Topic: weird today,  (Read 3750 times)
Offline Si
Re: weird today,
« Reply #20 on: 13 November 2005, 18:17 »
Damn Slick, how do u think of these things? I think my idea was better tho?!  :grin:
You will never turn me to the dark side!
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline Agreeable Slick
  • Unit
Re: weird today,
« Reply #21 on: 13 November 2005, 18:19 »
heh heh, many problems i have had in the past, and just a logical view on things that are technical. Bit of a geek when it comes to things like that,  :nerd: although i am proud of the fact, it has got me out of enough scrapes before.  :cool:
Re: weird today,
« Reply #22 on: 13 November 2005, 19:15 »
you need a hex bit (allen key) and a long thin extension to reach between the inlet & exhaust manifolds, and something to turn it with.  Something like this:
http://www.maplin.co.uk/Module.aspx?ModuleNo=10334
There are 6 bolts in total, and the second & third from the right are tricky to reach so make sure you can get to them before you start!
The way I did it was with a small ratchet, extension and I found a socket that would hold hex key to reach em :)
Re: weird today,
« Reply #23 on: 13 November 2005, 19:38 »
Heres a linky with a little more info and some piccies of what your o'ring probably looks like :)
http://www.hallvw.clara.co.uk/jettachoke.htm
You live anywhere near Bracknell?
Offline Volkswagavin
Re: weird today,
« Reply #24 on: 16 November 2005, 08:49 »
My old 1.6 driver throttle used to stick too.  More often than not, the throttle butterfly on the carb would dry up and become stiff.  A bit of WD40 sorts it out.
Carb freeze also used to get me whenever the air turned cold, but it was easily sorted.  There is (or should be) a pipe that comes up from the exhaust manifold which carries heat to the airbox.  If you have the standard airbox, check the hose is intact.  You may also need to check the vacuum hoses to make sure the flap opens when its cold to let the heat to the carb.  If you have a K&N bolt-on filter, get some of that aluminium heater pipe from halfords (or any good spares store...) and connect it to the heat outlet and tie it up so that the other end rests against the carb and the filter.  Point it somewhere else in the summer.
I like carbs...they're so simple...once you've had a carb car for a while, you almost always know whats wrong with it!
Gav
Mk2 Golf GTI 8v - J reg
Re: weird today,
« Reply #25 on: 16 November 2005, 09:09 »
Aye I know what you mean! Within a few months of owning my 1.6 the engine was running as sweet as a nut, but after over 6 months of ownership my 1.8 GTI still isn't quite right, there are just so many things that can go wrong!
Offline Haribo!
Re: weird today,
« Reply #26 on: 16 November 2005, 23:59 »
wd40 it is then and if that doesnt work then ill try the o`ring thing, is it possible that the throttle cable might be sticking? i want to be sure before i start taking the whole thing apart, i hate trying to fix this car, im no mechanic...  :sad:
Re: weird today,
« Reply #27 on: 17 November 2005, 09:50 »
Take the airbox off then get someone to press the pedal while you watch the linkage, you'll see if its sticking or not!
Offline Haribo!
Re: weird today,
« Reply #28 on: 17 November 2005, 12:00 »
even if it only sticks every so often? do i need to wait until it does it again?
