Author Topic: Where did my coolant go?  (Read 1478 times)
Offline GPT27
  • 1990 MkII 8v GTi
« on: 28 October 2005, 16:22 »
Drove to work this morning, nothing unusual at all happened.
Left my car for 5 or so hours, got in it at lunch time and drove away, coolant warning light was flashing, checked the bottle, it seemed empty, chucked a pint of water in it, drove about 1 mile, parked and left it for another few hours, checked the coolant and the full pint was still there.
I put another pint in and drove home, car behaved perfectly normally.
I don't check the coolant regularly but it was serviced about less than 2 weeks ago and the coolant was replaced so it should've been full.
Any ideas?
I checked the dipstick and the oil filler cap and the oil looked fine.
Judderi
Re: Where did my coolant go?
« Reply #1 on: 28 October 2005, 16:25 »
Who serviced it? John Wayne?
Offline bretttuk
« Reply #2 on: 28 October 2005, 17:35 »
Mine does this too, one time coolant seems ok .. other times its empty ... not got round to checking but probably blockage or leak somewhere..
Offline Organisys
  • Old and Slow...
« Reply #3 on: 28 October 2005, 20:10 »
Get a blue coolant header tank cap from GSF. Might stop some steam loss ?
 :smiley:
Offline Mr Blue
« Reply #4 on: 28 October 2005, 20:58 »
Ive got this problem. Goes down about half a pint. Gonna try the blue cap mod 2moro morning
you can get a dye that you put in your coolant which makes it easy to pin point leaks.
« Reply #5 on: 29 October 2005, 09:08 »
common spots for leaks are the 2 flanges on the block, the one on the front with the temp senders in and the one on the right hand side that goes to the heater matrix.
Offline baz_the_man62
« Reply #6 on: 29 October 2005, 14:46 »
you might wanna check around your water pump, mine was leaking sometimes but then it would seal itself up again... didnt bother fixing it.
Offline Diluxe
« Reply #7 on: 29 October 2005, 16:59 »
i used to get this till i got rid of all the air locks.............................
1997 16V
Offline monzablue16v
« Reply #8 on: 02 November 2005, 09:33 »
You might also find the thermostat housing has not been fitted correctly which causes it to drop the coolant when the engine warms up but if not a long distance Thermostat doesn't open and no water leak.
Offline zxrmatt
« Reply #9 on: 02 November 2005, 14:09 »
Mine was coming out through the coolant expansion header tank seem, when it had been running for some time.
Changed tank and was fine for a while, then leaking from radiator a few months later. Radiator then needed replacing .
