Author Topic: re: Golf Clubsport S for sale  (Read 390 times)
Offline stradman
« on: 12 July 2026, 21:25 »
Genuine Clubsport S No. 112 of 400 worldwide.  Car is Black metallic, however has a full body Matte PPF. I'm selling my car, that has been mildly modded out as an ideal Ring Tool. Car had most work done at the Ring at Raedermotorsport(sister company of Porsche Manthey) in 2023 as well as here in the UK at the Phirm. It is an immensely capable road/track car without being extreme in any way.   Car has 12,426 miles on it and is in mint condition. Unfortunately simply haven't been able to use it anymore.
The mods are:
Revo Stage 2 tune
402 hp on dyno
Airbox modifications
MST Performance Silicone Intake Hose & Turbo Inlet Elbow
Sachs Single mass Flywheel and organic organic clutch
Clutch delay valve and pedal spring deleted
APR coils
NGK High performance Spark plugs
Wagner Intercooler
HJS Downpipe
Racing line Catch can and drain kit
Racing line oil cooler(additional to OEM)
Recaro classic Pole Position seats
Recaro seat mounts
Schroth Profi 6 point harnesses
CAE ultra shifter
Wiechers Roll cage
TTRS front brake discs 370mm and calipers
RS3 Brake ducts
Goodridge Braided brake lines
Endless brake pads Front EIP184MX87
Endless brake pads Rear EIP251MX87 rear
Endless FR650 Brake fluid
Racing line Subframe Bolt Collar Alignment Kit
KW 3 way Clubsport suspension
HR front 26mm(soft setting) and rear 24mm anti roll bars
Whiteline Rear Heavy Duty Adjustable Anti-Roll Bar Drop Links
Manthey/Raeder Motorsport Geometry
Front: 3.4 degrees camber
+1mm Total Toe (Toe in)
Rear: 2.4 degrees camber
+3mm Total Toe (Toe in)
Protrack 9 x 18 ET 52 wheels
Wheel spacer 5 mm rear and 11mm front
Trofeo R's 245/40/18
Hot Pressures 28 PSI Front and 30 PSI Rear
Total weight with full fuel 1325kgs
Car comes with all its OEM parts along with Solo DL and Smartycam track data logger and camera. Also all books and second key. The car is ready and perfect to enjoy as is. However as all OEM parts come with it, it would be fairly easy to convert it back to OEM if you like and then sell the modification parts accordingly(at least 11-12k worth on the second hand market). Price is £37.5k Happy to answer any questions accordingly of course.
