Author Topic: Bonnet Strut  (Read 15531 times)
Offline valentino
Bonnet Strut
« on: 12 February 2026, 09:30 »
Just wondered if anyone has fitted a bonnet gas strut to the 8.5?
Offline JoeGTI
Re: Bonnet Strut
« Reply #1 on: 12 February 2026, 09:41 »
Yep! I got the RacingLine one for my MK8 5 years ago and I moved it to my 8.5 when I changed last year.
Offline CrunchtheApple78
Re: Bonnet Strut
« Reply #2 on: 12 February 2026, 10:05 »
Oooh, good shout. Is it easy to change? I think it’s such a dangerous thing not to have a gas strut. The risk of broken hands/wrists is too high.
I’m waiting for my new CS at the moment, so will order one if they are an easy DIY’er fit.
Offline JoeGTI
Re: Bonnet Strut
« Reply #3 on: 12 February 2026, 10:16 »
Very simple DIY job. 5 minutes.
You undo this one bolt on the bonnet itself and replace it with a bolt that's included with the strut. The other end of the strut slots into a slot on the chassis that is still there for that exact reason, despite the lack of said strut.
Offline valentino
Re: Bonnet Strut
« Reply #4 on: 12 February 2026, 10:34 »
Thanks for that Joe. Does it clear all the vulnerable bits in the engine bay? I read that some brands of gas strut can cause rubbing issues
Offline JoeGTI
Re: Bonnet Strut
« Reply #5 on: 12 February 2026, 10:37 »
Oh yeah, so the rubber hose from the coolant reservoir may rub on it when the bonnet is closed. Easily solved by loosening the clamp on that hose (with a pliers) and turning the hose to the right, about 45 degrees, so it'll no longer foul the strut.
Offline valentino
Re: Bonnet Strut
« Reply #6 on: 12 February 2026, 10:44 »
Thanks Joe
Re: Bonnet Strut
« Reply #7 on: 12 February 2026, 10:57 »
Great info, thank you.  :grin: Ordered!
Offline valentino
Re: Bonnet Strut
« Reply #8 on: 12 February 2026, 14:06 »
ORDERED
Offline Beebopper
Re: Bonnet Strut
« Reply #9 on: 13 February 2026, 21:05 »
It’s a worthy mod, not very expensive either. Racingline provides detailed instructions, it’s simple and takes 5-10mins, just make sure you adjust the coolant hose as detailed to avoid running (as Joe says).
Prior - MK2 GTi Big Bumper in White
Current - MK8 GTi Clubsport in Moonstone Grey
(Plus Many other non-Golf hot-hatches in-between!)
