Author Topic: 8.5 Steering Wheel on an 8?  (Read 9811 times)
Offline flipflops
« on: 31 January 2026, 19:27 »
Hey, has anyone tried to fit an 8.5 SW to an 8 to delete the horrible haptics? Bolt on, bolt on and code or does it not work at all?
Thanks
Offline Dav3smith
Re: 8.5 Steering Wheel on an 8?
« Reply #1 on: 31 January 2026, 19:42 »
Not me. I actually have no issues with the haptics and prefer them.
Why do you dislike them so much to the point where you want to change?
GTI Clubsport ED45 DBP, DCC, HK, WP, Pano
Gone Golf R 7.5
Gone GTI 7
Offline flipflops
« Reply #2 on: 31 January 2026, 19:50 »
I find I use the bottoms a lot and know my way round the non haptic version without looking, the haptics are just a bit of a faff and not as accurate when using without looking
Offline Dav3smith
« Reply #3 on: 31 January 2026, 19:58 »
Fair enough and I understand what you mean about pressing intuitively. I guess I don't use them that much to be concerned by this.
Gone Golf R 7.5
Gone GTI 7
Online JoeGTI
« Reply #4 on: 01 February 2026, 01:07 »
You don’t need to swap the entire wheel. The buttons are a straight swap. No coding required.
Offline davo245
« Reply #6 on: 01 February 2026, 08:20 »
Thanks
https://youtu.be/3qgkk-ND4uo?si=EmpNebV-OyAOzUov
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline flipflops
« Reply #7 on: 01 February 2026, 12:16 »
Thanks both, game changer!!!!
I've been looking at CS's for a while, 8.5 are nice but still ££ so a slightly older 8 CS with normal buttons would be perfect :)
Offline fredgroves
« Reply #8 on: 01 February 2026, 21:54 »
It's not nearly as bad as one press guy wrote about (and every other lazy journo copied) but swapping them out is possible as described above. Personally I'd not bother.
Offline flipflops
« Reply #9 on: 01 February 2026, 22:54 »
Thanks, I test drove one a while back and obviously didn't live with it but wasn't a massive fan. I use then constantly in the 7.5 for cruise and audio, I'm happy with the swap, genuine parts and can swap back if needed :)
