Author Topic: 8.5 Clubsport and no DCC  (Read 21554 times)
Re: 8.5 Clubsport and no DCC
« Reply #10 on: 14 January 2026, 15:56 »
As said previously, everyone has different tolerances and ideally you should try both.
For my tuppence, I lived 3 years with a non DCC mk8 Clubsport and not once did I wish I had it. The 8.5 might have fractional differences in suspension settings but I doubt anything hugely significant.
The Clubsport has stiff(ish) springs and hard(ish) bushings for optimal handling so no matter how soft you set the dampers it’ll be the springs and bushings that ultimately dictate ride quality.
Hit a pothole with DCC or no DCC and boy will you know about it.
Following the Clubsport I had 18 months with an 8R and now around 5 months with an 8.5R. The former had no DCC and the latter does have it. On some roads the ride in the non DCC R was brutal when doing long distances and in the DCC car a bit less so. So the R seems to have harder bushings. The main difference between the two is a slightly smoother ride on jiggly roads in the DCC comfort settings but when you hit the really rough stuff both types of suspension struggle, and if you drive on really bad roads a lot it’s definitely be cheaper to replace non-DCC parts when the dampers fail, which both types will eventually.
It seems a bit odd that DCC builds have a longer lead in time as I’d have thought it would be a popular option and in good supply. Maybe speak to more than one dealer.
Offline davo245
« Reply #11 on: 16 January 2026, 07:18 »
I had a 7.5 performance with DCC I spec'd as a paid option from factory also on 19s, I now have a MK8 Gti without DCC also on 19's and find the suspension perfect never once do I ha paid for DCC I would not pay extra for it again.
Found myself never really changing it on 7.5 tbh I know they only had 3 settings unlike the 8 but comfort was too soft and sport to hard for most surfaces so just left in normal most of the time.
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline PAS
« Reply #12 on: 16 January 2026, 08:33 »
Almost every owner will have their tuppence to throw in to this discussion (understandably) as ride quality is a notoriously personal thing - over-stiff ride for one driver is exactly what the next owner was hoping for (particularly in a GTI).
So clearly the best advice is to drive two different 8.5 Clubsports (one with DCC and one without - same size rims) if that is possible to arrange, before you decide.
I owned two 7.5 GTIs both on factory 19's and neither with DCC - for me the ride in both was firm but no problem at all.
I then ran an 8.5 R Line 1.5 TSI on factory upgrade 18's for a year and again I found the ride to be firm but no problem - interestingly though I noted that I had gone down from 19" to 18" wheels and off of GTI suspension but the ride felt just as firm as the Mk 7.5 GTI's on 19's....
I am now in an 8.5 GTI on standard 18's with standard suspension (no DCC) and the ride is every bit as firm as I would want it - particularly at low speed around town - I am actually binning the OEM Bridgestone S001 tyres early as their hard tyre walls are really not helping this.
So my 2p worth would be beware the harder ride of the 8.5 GTI - I wish now that I had gone for a DCC car.
Ride aside, the new 8.5 GTI is fantastic - goes harder than the 7.5 GTI PP and steering/handling is certainly improved - just watch that ride quality if you want it to handle all of the daily grind jobs for you as well as the weekend fun stuff.
What tyres are you looking to replace the Bridgestone's with?
Offline CarbonGTD
« Reply #13 on: 17 January 2026, 13:26 »
PAS - it would have been an automatic choice for me to swap the crappy Bridgestones for four new PS4S's as I have used these several times before on previous GTIs and have always loved them - however they are now a 10yr old design and my head has been turned by the reviews for the new Pirelli PZ5 which sound exactly what I'm after (PZ5s are also cheaper than the PS4Ss) - so it will be a new set of four PZ5s going on the car as soon as the first shoots of spring appear.
Offline The_Doc
« Reply #14 on: 17 January 2026, 15:59 »
I have an 8 CS. The ride is definitely softer on the soft DCC setting than the shocks on the non DCC cars, but neither is necessary. The big reasons to get it are the Nurburgring mode, which is something people might look for when you come to sell it. It is a nice thing to have but again not necessary. The big advantage is the new dynamics manager which if you have DCC can vary the dampers in response to things like body roll. It takes and engaging car and makes it even better. I opted for it on my CS, and I’d do it again. I found it made a small but meaningful difference to the way the car responded.
Current - MK8 CS - Dolphin Grey, DCC, Black Estoril, Rear Camera, Sunroof, Winter Pack, Harmon Kardon
Previous and sorely missed - MK7.5 GTI Perf, Indium Grey, Brescias, Art Velours, Rear Camera
Offline PAS
« Reply #15 on: 18 January 2026, 16:22 »
Thanks CarbonGTD, I would be interested to hear your views on the Pirelli's when you have had them fitted. I too have the Bridgestones and and always thinking what tyre I would replace them with when the time comes.
Offline Gunnsie
« Reply #16 on: 19 January 2026, 22:02 »
I have an 8.5 CS and even with DCC in comfort mode it's definitely on the firmer side for daily driving in the sh!t English roads around where I live (Surrey / South London)
The second biggest thing about DCC on the 8.5 CS is it gives you Nurburgring mode which is beautifully setup for those horrible English roads, but also gives you Manual + gearbox mode which lets you bounce off the limiter instead of auto shifting up
