Author Topic: Any ideas what this could be please?  (Read 141874 times)
Offline Nino
  • Insta - F6UGA
Re: Any ideas what this could be please?
« Reply #50 on: 11 December 2025, 08:52 »
Hate to say it but sounds like it hasnt been verywell looked after by the previous owners.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline Adam T7
« Reply #51 on: 11 December 2025, 10:14 »
I had a Discovery 4 that had a perpetual problem of going into limp home mode when revs got above 2k (when the second of the two turbo’s kicked in) Replaced MAF sensors, CSV etc eventually solved with a smoke test - minute pin hole in a seal on the connecting pipe - part cost about £2 and took 30 minutes to fix.
Fingers crossed yours is as simple and cheap.
Offline Norwichdaz
« Reply #52 on: 11 December 2025, 22:28 »
Lets all pray hahaha 🙏
Offline Norwichdaz
« Reply #53 on: 11 December 2025, 22:29 »
Been serviced etc all good, bit maybe at the mileage its due for a few things...which im.not gunna keep paying loads as the car  was only bought for £2.5k lol
Offline Norwichdaz
« Reply #54 on: 11 December 2025, 22:32 »
And be silly.getting waterpump done when in same area as timing chain but then it goes from a £600 job (thats enough lol) to nearly 2k... when the engine is high anyways lol..running fine tho and plenty of poke etc.. but yeh coolant is wierd,
Offline Norwichdaz
« Reply #55 on: 21 December 2025, 08:19 »
Still losing coolant, garage said looked like could be from the heater pipes so could need those changing rather than the matrix lol..
Also no leaks in footwell or smell iside the car  and no visible leaks on the floor either and heat when I turn the heating up.
Did think il check the 2 pipes at front of the engine from the reservoir which wrap round the front of the engine.
Offline Nino
  • Insta - F6UGA
« Reply #56 on: 21 December 2025, 14:07 »
I had a similar issue on my MK6 2.0 TDI, turned out to be the Radiator I replaced it myself on my drive, took me a few days as I was waiting on parts but I did have my other car I could use in the meantime so wassn't bothered.
Popped the front end up on Axel stands, removed the bumper, the headlights, crashbar then it was really easy to access the Rad to swap it out, naturally, dont forget to drain the coolant then replace it.
word of warning, these engines love to airlock. When you topup your coolant after the job being done, run the car upto temp with the coolant cap off. then put the cap on and go for a drive, about 10-15 miles, make sure you kjeep a 5L bottle of already mixed coolant in the boot to top up, over time, the car will get rid of the airlocks and you will get a low coolant warning on the dash. I had this for about 3 drives over 3 different days, I wanted to let the engine cool down overnight, then went for a drive, after 3 days of doing this, all the airlocks were gone and my coolant levels were sorted.
Also remember to have the heating on HOT and full blast int he cab when you do this.
Offline Norwichdaz
« Reply #57 on: 21 December 2025, 14:39 »
Ah ok thanks,
 Obviously I have been reading alot about this kind of thing lately lol...did see about running car with no cap on tbh about the airlock etc... would an airlock.make coolant leak tho?
But yeh the 2 coolant pipes front of engine font seem too much to replace if did that, like i say the guy said about the heater pipes but thats turbo side of the engine.
Will get it checked again I thjnk and even get them to do the dreaded head gasket test lol...as I say doesn't overheat etc,car runs fine just Obviously in my head I dont want to go on a longer journey for the coolant loss.
I know Obviously a chance of a water pump too which been told.around £600.
And I guess radweld is a nooooooo 😆 🤣
Offline Norwichdaz
« Reply #58 on: 21 December 2025, 17:27 »
Forgot to show these when the mechanic said these pipes seem to be where was a leak.
Offline Nino
  • Insta - F6UGA
« Reply #59 on: 22 December 2025, 09:08 »
Ah ok thanks,
So, no, air locks 100% will not cause coolant leaks. its hard to tell from your pictures if the pipes are broken to be honest.
That black unit with coolant hoses is almost certainly the auxiliary coolant pump (often called the turbo after-run pump but also known as Auxiliary water pump, Turbo coolant pump, After-run pump).
It’s an electric water pump that circulates coolant after the engine is switched off its main job is to cool the turbocharger and cylinder head, preventing heat soak it can also run during certain driving conditions to help manage coolant flow.
They can go faulty but its not super common for them to break.
You tend to get coolant leaks from the pump body, Internal failure causing coolant circulation faults they are often replaced together with hoses because the plastic gets brittle.
Looking at your pictures, I am not convinced that pump is leaking.
- The top and side of the pump housing are dry
- The coolant staining looks baked-on and dusty, not wet or fresh
- The residue pattern looks like it’s been dripping down onto the pump, not originating from it
- If the pump housing seam or electrical body were leaking, you’d usually see, fresh pink/white crust right at the seam & dampness around the hose connections
Coolant leaks love to travel downward, and this pump sits low. Typical culprits are above it, very common leak sources above this pump on Mk6 GTIs can be, Water pump / thermostat housing (EXTREMELY common on EA888), Plastic housing warps or cracks coolant drips down the front of the block, Upper radiator hose connection, coolant flange on the cylinder head, expansion tank return hose & oil cooler seals (coolant + oil heat exchanger area rare).
Any of these will drip down and coat the aux pump, making it look guilty when it’s just the victim :undecided:
My advice going forward before you spend any serious money would be, Clean the area with brake cleaner and get that pump super duper clean. Drive for a day or two, Recheck with a torch → the highest wet point is your leak.
Even better (But will cost money)
- Cooling system pressure test (cold engine)
- UV dye in coolant (shops do this quickly)
But, if I had to guess, I would agree, its likely the Water pump or Thermostat.
I agree with you, not worth replacing the Water pump unless your doing the timing belt as well, likely due anyway.
As for your Head gasket, these are not fords, you don't have to worry about that  :grin:
