Author Topic: Any ideas what this could be please?  (Read 141821 times)
Offline Nino
  • Insta - F6UGA
Re: Any ideas what this could be please?
« Reply #20 on: 28 November 2025, 07:44 »
Stick with OEM unless you plan you go Stage 2 then I would recommend Forge only.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline Norwichdaz
« Reply #21 on: 28 November 2025, 11:19 »
Ok, just using it almost as a daily tbf so won't be staging it and done 155k tbf...
Well, was about to come and say all running well since had car back this morning, and before had the pcv,plugs and coil it looked more like it was minus 10 outside with the exhaust/steam out the exhaust but now there's none of that and a tiny bit from the exhaust that u can see so thought, nice sorted.
But the "blowing noise is still there on decel" and as it was at idle nothing wrong in the revs , nice and settled, but u get a little putt, few seconds later putt...
And the ecl light flashed up 🙄🙄...
Offline Nino
  • Insta - F6UGA
« Reply #22 on: 28 November 2025, 11:49 »
It never rains does it - You might have a leak somewhere between the turbo and exshuast.
Offline Norwichdaz
« Reply #23 on: 28 November 2025, 12:48 »
Yeh i know  :shocked:
Found some stuff about wastegate failure? And found this video ( u can hear the sound at the start)
Which does sound quite similar to my original video tbh.
The clip he talks about tho, looks like fits onto an external one I thought mk 6 turbos have them internally so surely the clip wouldnt then work.
https://youtu.be/211EPtuQ158?si=GfI3JOIqNHfg13ra
Offline Nino
  • Insta - F6UGA
« Reply #24 on: 28 November 2025, 12:55 »
its possible, personally if I was you, as long as you are not;
- Losing oil
- Losing coolant
- Blowing lots of smoke
- Losing boost
- Have horrible sounds from the engine
I would enjoy your car over the Christmas period then get it booked in the new year to a specailist.
Where abouts are you located?
Offline Norwichdaz
« Reply #25 on: 28 November 2025, 18:29 »
Earlier also I have Engine light on, good old Google said its possible after the 3 new things I've had yesterday aslong as goes away after a couple of days?
Like I say it drives fine (not that I've booted it) and also to be cautious with the light on now.
Coolant seems ok atm .
Is it possible to replace the actuator/wastegate if its/thats this rattle and the sound on that clip?
Or is it fully enclosed and you cant open the turbo up to change that part anyways?
Im in Norwich fella
Offline Nino
  • Insta - F6UGA
« Reply #26 on: 29 November 2025, 09:24 »
Yeah you could be right to be honest - Only real way to tell is get until the car and see if there is play.
Offline Norwichdaz
« Reply #27 on: 29 November 2025, 10:12 »
Yeh just depends if its.fully sealed unit, as seen on some obviously a little easier if its outside the turbo...looking online for a turbo for it looks pretty sealed i think  :undecided: :nerd:
Offline Norwichdaz
« Reply #28 on: 30 November 2025, 02:43 »
Just for now etc in just ordered a wastegate clip see if that helps lol
Offline Nino
  • Insta - F6UGA
« Reply #29 on: 30 November 2025, 12:36 »
Yeah, good shout.
You clearly had other issues with the PCV as well so just as well you got that sorted.
