Author Topic: Mk8.5 gti key battery no warning!  (Read 18860 times)
Offline Skyered
« on: 18 November 2025, 19:13 »
Having owned 2 previous golfs (gtd & gti) i was used to getting a warning when my key fob batteries were low. Generally speaking you need to replace the batteries in the key fobs every year being keyless cars. However now having a mk8.5 gti there was no warning.....the key simply died. Doing a search using the built in manual for the car it simply says the key fob battery needs changing when it becomes unresponsive...going to keep spare batteries cr2032 and a small screwdriver in future in the car but is this another cost cutting exercise by vw? Or am i missing something....
Offline Watts
Re: Mk8.5 gti key battery no warning!
« Reply #1 on: 18 November 2025, 19:59 »
My 7.5 gave no warnings too.
Previously:
Offline MarkHowells
« Reply #2 on: 18 November 2025, 22:30 »
That's strange because I had a warning when my battery was low. I ignored it for a while and it stopped warming me, but then I had an email from my local VW dealer asking me to call them as my vehicle has a standing alarm.
The VW dealer called because I have set them up as my authorised workshop in my VW app.
Current: 2024 Golf GTI 8.5. Oyster Silver metallic black, black roof, Queenstown alloys, DCC, HK, spare wheel
Gone: 2018 Golf GTI 7.5 performance pack, Atlantic Blue, Santiago alloys, DCC.
Gone: 2014 Golf R, Lapiz Blue, Vienna leather, DCC.
Gone: 2011 Golf GTi, Reflex Silver.
Offline Carlosfandango
« Reply #3 on: 18 November 2025, 22:54 »
You don’t need a screwdriver, simply pull the emergency key from the fob and use it to push the rear cover off through the gap left from where the key was.
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline DSGboy
« Reply #4 on: 18 November 2025, 23:25 »
My 2019 R gave the required Key fob Low Battery recently.  Renata CR2032 to the rescue.
Shame I didn’t respond equally swiftly when our Hive thermostat warned. Cold showers for spouse are never welcomed.
Gone. Mk6 GTI DSG, 2012 ,5dr , DPB, 18’s, Leather, Dynaudio, Cruise, DAB, Auto Mirrors, Storage Pack, TPMS.
Current. Mk7.5 R DSG, 2019, 5dr, DPB,  Pretorias, Leather, Memory Seat,  Climate Screen, Rear Camera, Black Caps
Offline ar899
« Reply #5 on: 20 November 2025, 12:20 »
No wonder fob batteries going quicker these days. Press once for drivers door, another for other doors, yet another for the boot. What ever was wrong with press once to open, press again to close.... Another example of car technology solving a problem that didn't exist.
Offline fredgroves
« Reply #6 on: 20 November 2025, 12:32 »
Only if you've got those security measures turned on.... me I've got keyless set, it just opens all of the doors and the boot or just the boot if I walk up to the rear.
Its not the button pressing anyway, its the UWB ranging signal its pinging all of the time that kills it.
And on the Mk8 you do get a low bat warning, but only sometimes - not constantly, not even when its really struggling. Guess the mechanism it uses for determining it is a bit flakey. I've had it go flat several times with zero warnings at all.
Offline JoeGTI
« Reply #7 on: 20 November 2025, 13:12 »
I had to change my MK8.5 key fob battery within about 7-8 months of ownership. I definitely had the warning in the dash about it. I was seeing the warning intermittently flash up for weeks before I got around to replacing it.
« Reply #8 on: 20 November 2025, 23:57 »
I keep my key in a faraday pouch, just over a year of owning my current 8.5 and it’s not required a new battery. As mentioned above, it’s the range signal thing ‘talking’ to the car that kills the key battery, the faraday pouch stops that happening, especially if your key is kept in range between drives. My previous mk8 needed a key battery twice in quick succession until I realised the key was being woken up by my hall table moving as I walked past it, this made the key talk to the car, which also made the coming home lights on the car activate, all of this stopped by using a faraday pouch.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
« Reply #9 on: 30 November 2025, 12:18 »
At just over 4 months old I had this warning pop up today.
Faraday pouch required I think!
In a fraction under 5 years of mk8 & 8.5 ownership I’ve had a mixture of batteries lasting ages then failing without warning, and gradual deterioration with warning messages flashed up.
I’ve tried a variety of batteries too, Panasonic (OEM) & Duracell seem to last reasonably well.
