Author Topic: Lighter wheels = Rougher ride?  (Read 32817 times)
Offline fredgroves
Re: Lighter wheels = Rougher ride?
« Reply #10 on: 20 November 2025, 12:30 »
You say OP that its 10% worse... would that be roughly the difference in the weight of the wheels+tyres you swapped out?
The dampers are "tuned" for a (range of) weights of wheel on the corner and the resulting forces.... and you've changed it quite a bit. Changing it a little you might not notice much (eg different tyres or swapping OEM 19's for 18's)
Offline MinchCS
« Reply #11 on: 20 November 2025, 13:36 »
The 18' Belvederes on the ED 40 (with same DCC) are even lighter than the OP's set up though so well within DCC factory parameters.
2017 black Clubsport S
Offline fredgroves
« Reply #12 on: 20 November 2025, 14:22 »
Same DCC though on an ED40?
Exactly the same dynamic shock part numbers?
Offline MinchCS
« Reply #13 on: 20 November 2025, 15:16 »
Front dampers yes. Share same number.
Rear ED damper part number has now been superseded (twice) but I think they are the same parts too.
And you could order belvederes on normal GTi too.
The software might be different though.
« Last Edit: 20 November 2025, 15:18 by MinchCS »
