Author Topic: Racingline or Revo  (Read 61376 times)
Offline Bluest
Re: Racingline or Revo
« Reply #10 on: 20 October 2025, 14:39 »
With the Revo 40% Black Friday deal, it more or less offsets the cost of the SPS, so could look it at as getting the SPS for free in effect.
The waffle on the Revo site says that setting 1 is stock mode, but I assume from your post that this isn't truly the stock map back in the car. Whereas with Racingline I would be actually changing the map myself each time? However, I don't I don't have a Windows laptop or a 20 amp battery charger, which rules that out unless I want to spend more cash.
There is also the Mountune Smartflash as another DIY option. Slightly cheaper than the above 2, also offers a supposedly clutch friendly low torque map. I used to own a Focus ST and Mountune are highly regarded in those circles, but whether they are good in the VAG-world I do not know. I don't know if this functions more like the Revo SPS or the RL PDM though.
Offline dilligolf
« Reply #11 on: 20 October 2025, 15:29 »
My undersanding with the SPS is setting 2 is for 95 RON, 3 for 97 RON, for 99 RON.
Each with differibng/higher settings for Boost, Fuelling and Timing. I cant find the link that includes the out of the box settings, and not expained in https://www.onlyrevo.com/spspopout?spsmode=7.
Out of the box the 3 modes are pre configured, and your VAG dealer would not need to change a thing. SPS setting 2 boost, fuelling and timing arent  stock to my knowledge.
https://www.onlyrevo.com/product-details/accessories/serial-port-switch-sps then contradicts that saying a stock mode is avaiable.. but... doesn't state which setting. Might be worth asking the VAG dealer?
With Racingline I think you'd use your mobile joined to the PDM via bluetooth, so flashing via your mobile. Eliminates the need of a laptop, but, would need a charger.
Racingline seem to have a history of and were an original tuning arm of VW motorsport, and Revo developed tuning for VAG, while with Motune IIRC someone jumped ship from Racingline/Revo.
Alternatively would the physical Raclingline PCM or Burger JB4 be an alternative option? https://burgertuning.com/
Offline Bluest
« Reply #12 on: 20 October 2025, 16:00 »
This is the Revo options with the SPS. I guess I would go with Option 3 for modes.
Offline dilligolf
« Reply #13 on: 21 October 2025, 08:11 »
Bingo!
Looks like the SPS settings change based on the engine selected  :wink:
Offline SuperScaff
« Reply #14 on: 22 October 2025, 05:18 »
I have Revo with sps switch and find there is quite a difference between the 3 performance settings, I’m on stock mode currently as I have a new clutch/flywheel I’m bedding in so taking it easy for now
The anti theft mode is also good for when I have to leave it parked up somewhere
Offline Bluest
« Reply #15 on: 22 October 2025, 11:22 »
Thanks Super Scaff. Do you have any experience with the revo low-torque maps on a standard clutch?
Offline SuperScaff
« Reply #16 on: 22 October 2025, 16:47 »
Yes, that’s what I have on my car as it’s a 6mt but still made the clutch start to slip in the higher gears after a few thousand miles. Starting slipping in 5-6 when planting the pedal than started slipping in 4th so have had a Helix upgraded clutch with Sachs flywheel kit installed
Offline Bluest
« Reply #17 on: 23 October 2025, 11:33 »
Probably a separate thread, but what are the friendliest uprated clutches for a Stage 1 car? I.e. least increase in pedal effort, smoothest in stop start traffic etc. There is always a trade off with these things.
Offline SuperScaff
« Reply #18 on: 23 October 2025, 13:30 »
All my research pointed to the Helix upgrade with organic clutch plate and can confirm it’s definitely heavier than oem but not over the top, the feel of it is amazing when shifting thou the gears much more grabby makes the car feel more alive   :cool:
https://www.akstuning.co.uk/shop/home/1168-helix-dmf-performance-clutch-kit-mk7-gti-octavia-vrs.html
Offline ProtoCulture
« Reply #19 on: 11 November 2025, 22:24 »
I've got Revo stage 1 ECU and TCU. When I had mine done the SPS was like rocking horse poo to get hold of, picked one up off eBay for ~£50 I think it was.
The SPS only tells the ECU to use setting 1, 2, 3, or 4, the map settings are stored in the ECU.
For my Mk7 the settings are as follows.
1. Stock
2. Remapped for 95 RON
3. Remapped for 99 Ron
4. Anti Theft.
2016 Tornado Red GTI PP, DSG, Pro Nav, Dynaudio, Park Assist & Camera.
Mods: Revo Stage 1 ECU & TCU remap. Racingline R600 with Inlet pipe, turbo elbow and muffler delete. Clubsport S backbox. Eibach lowering springs. VBT Hooked discs and Racingline RP700 pads, braided lines and RBF660 fluid.
Protrack One wheels (18x8, ET45) 12mm spacer on rear.
Geo by Swift Performance
