Golf mk6
Snoopy
Rattle between 1700rpm and 2000rpm
Topic: Rattle between 1700rpm and 2000rpm (Read 67538 times)
jdoubleu
03 October 2025, 09:37 »
There is a rattle that is annoying me and I cannot trace it. It sounds to me like it's coming from the front of the car rather than the rear (the attached video is right under the front subframe which is probably obvious). It is not present at idle, comes in around 1700rpm and fades above 2000rpm. It is much more noticeable outside the car (if you have the windows up, you can only really just about hear it).
https://packaged-media.redd.it/naupkame2qsf1/pb/m2-res_1080p.mp4?m=DASHPlaylist.mpd&v=1&e=1759496400&s=ca9812d7f39687b83a946eaa4dc2e067be3cc84e
I've had the car up on ramps to have a good look around and nothing is obviously loose. It is worse when the car is under load (e.g. pulling up a hill) but does do it even when stationary as per the video.
The car performs absolutely fine. The engine sounds sweet in every other regard, pulls great and doesn't give any errors.
Is this noise familiar to anyone? I am aware of the common wastegate rattle but it doesn't seem to quite match other recordings I have heard of that (but correct me if I am wrong).
JSYGTI
Re: Rattle between 1700rpm and 2000rpm
04 October 2025, 07:11 »
Any lose heat shielding anywhere, mine has a rattle similar, but I’ve not got around to sorting it yet.
jdoubleu
04 October 2025, 08:17 »
I've been under the car front to back and just cannot see a simple heat shield loose. I even removed and refitted the rear heat shield above the back box with new fixings as it seemed slightly loose. But no change to this noise, sadly.
SRGTD
04 October 2025, 08:55 »
Maybe fuel lines or brake lines rattling against the underside of the car? I can vaguely remember reading of this being a cause of underbody rattling noises on a golf forum in the past - maybe it was this forum?
Gone but not forgotten;
2016 Polo GTI; Blue Silk
2002 mk4 Golf GTI (the 150 bhp diesel version); Deep Black Pearl
jdoubleu
04 October 2025, 11:05 »
Yeah, it's a good shout but I forgot to say I've also zip tied the fuel lines already as per other posts suggest. No dice though...
weejockvw
05 October 2025, 12:35 »
I’d check the clutch maybe dual mass flywheel
Snoopy
Moderator
Serious forum addict
Geoff.
Reply #6 on:
05 October 2025, 15:53 »
I cannot really tell from the video but is it the waste gate rattle they are renowned for is it? As that happens at those revs.
Plenty of videos out there of how to bend the rod and or fit the clip.
Current Garage:
Mk6 Golf GTI ---
Mk1 Golf GTI ---
Mk1 Leon TDI ---
Mk1 Mini variant.
35+ years of GTI ownership.
jdoubleu
Reply #7 on:
06 October 2025, 22:42 »
I've now actually fitted the wastegate clip as a just in case, but the noise sounds the same to me.
I might have to park the investigations for a bit - spent too long on it already
Thanks for the suggestions.
Nino
Insta - F6UGA
Reply #8 on:
08 October 2025, 09:19 »
Quick question, I can hear a slight hiss in the video too.
Have you checked the PCV is ok? and odd question, was your Climate control set to Auto during this video?
Turn off your AC/Climate and try it again see if the noise goes.
Last Edit: 08 October 2025, 09:29 by Nino
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35 - Candy White - 3 door.
jdoubleu
Reply #9 on:
09 October 2025, 21:03 »
No, the AC would not have been on when I recorded that video.
I took the car on my commute today and it could be a placebo but might have been the noise was less noticeable. Perhaps the wastegate clip did make a difference... Harder to tell at the moment as it's coming into "windows down" season. Will monitor over the next few outings!
Golf mk6
Snoopy
