Author Topic: Anyone know how to buy dipstick mk8.5 gti  (Read 36688 times)
Offline jme63
Re: Anyone know how to buy dipstick mk8.5 gti
« Reply #20 on: 06 April 2025, 19:36 »
Be interested to know how easy you find removing the plug is. I've tried but it feels that it would take more force than it would to remove a dip stick.
It also has  green witness marks that are aligned on the  plug and tube, similar to the white witness marks on the oil filter housing; I think  to indicate the filter housing has been torqued in the factory.
Offline Carlosfandango
« Reply #21 on: 06 April 2025, 20:22 »
I also tried to remove the cap a while ago, it’s actually clipped in place unlike the dipstick, I got the impression that the clips may break if I removed it, so left it alone, but now I have a dipstick I'll remove it, broken clips or not! Witness marks wouldn’t bother me tbh, as i bought the dipstick from the dealer parts department based on my VIN number, the parts guy said the exploded view he had on screen showed the cap and dipstick as separate available items.so presumably it is perfectly acceptable to have either in place.
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline seanaodh
« Reply #22 on: 17 April 2025, 16:35 »
Did you give this a try carlosfandango? I don't think I'd be brave enough to break clips off on a new car like this :)
« Reply #23 on: 17 April 2025, 21:14 »
Totally forgot to pick the dipstick up to be honest! Didn’t even remember I’d ordered it until I read your post  :shocked: , I doubt the parts department is open on Friday though as it’s a bank holiday, so I’ll pick it up on Saturday and let you know.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
« Reply #24 on: 19 April 2025, 21:42 »
So.. I picked up the dipstick today, and put it in place, Turns out that the blanking cap is only held in place the same way as the dipstick itself, it’s just harder to pull on as it doesn’t have a ring to hold on to, so no clips were broken, i did however use a small screwdriver to pry at the plug, but in hindsight i could have just used some pliers and pulled straight upwards. 🙄.
The part number of the dipstick is 06K -115-611-AB. And after some checking and adding 250ml of oil, I can confirm that the electronic oil gauge on the infotainment, and the physical dipstick itself, match in terms of level displayed 👌. A simple and well worth it mod, if like me you like to be able to see for yourself that the level is correct.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline Buster 1234
« Reply #25 on: 11 December 2025, 15:47 »
I'm new to the Forum, so if the question regarding oil dipsticks for Mk8.5 Golf GTIs has been sorted, then I apologise.
I got a new GTI in October and was disappointed to find that there is no dipstick, so I contacted my local VW outlet and ordered one. Part number 06K-115-611-AB cost £20.72 and arrived within 2 days. The plug in the dipstick tube is easily removed with a pair of 'grippy' pliers. Just grasp said plug firmly, then slowly twist and pull. Granted, it did seem to be remarkably unwilling to part company with the tube, but I think that was due to there being a robust sealing ring set into the plug.
Offline artie
« Reply #26 on: 11 December 2025, 16:03 »
Hello, first post so be kind! So the mk8.5 does not come with an oil dipstick even though it has the necessary pipe with a "dummy" yellow dipstick. Yes the car now has a sensor and I can see the level on the display but being old fashioned i miss the dipstick...anyone fitted one? Don't want to go down the aftermarket route as they seem expensive. Thx
Pretty easy and not too expensive
Offline Watts
« Reply #27 on: 11 December 2025, 16:10 »
I'm okay with the electronic dipstick. I like that I can keep an eye on the level whilst driving and can therefore check it more regularly than I would otherwise. I also think that most owners (perhaps not so much the enthusiasts on here) would rarely if ever venture under the bonnet and check levels, even though they should.
Previously:
