Author Topic: vr6 engine conversion  (Read 20374 times)
Offline paul1972
« on: 02 February 2025, 18:53 »
good evening
was wondering can anyone help ive recentley bought an oak green 90 spec the orginal engine was nackerd so its had a 12v vr6
 engine sat in place the hydraulic pedal box  is in place but needs plumbing in could do with a diagram and part list for plumbing it in
think i need a different btake resevoir to plumb the clutch and slave cylinder in
i have the mkk 3 clocks ecu and wiring harness but could do with the wiring diadram for the loom and fuse box its obd1 with a coil
fitted
the car requires a restoration but would like to get the engine running then pull it back out for its new paint job
Thanks Paul
