Author Topic: I bought an 8.5 GTI from stock  (Read 10776 times)
Offline DrivenToDistraction
Re: I bought an 8.5 GTI from stock
« Reply #10 on: 06 December 2024, 19:36 »
Good to read your update DTD, it all sounds very positive so far.
How do you find the engine drives in normal driving compared to your previous GTI, does it still have the same low end flexibility now that they’ve added a few extra horses or has there been a sacrifice? It’s stuff like that which is important every day which only regular users can appreciate as opposed to a YouTuber thrashing around for an hour in sport mode using someone else’s fuel.
Thanks. Yes, overall, very positive. It not easy to compare with my 7.5 as I am having to get used to the DSG again after 3 years in a manual, but the engine/turbo combination definitely has a lot more grunt. Not too surprising as my 7.5 was not a PP so "only" had 227 BHP. Someone upgrading from a mk 8 might be better placed to answer that question. However, the way that the power is delivered is more 'urgent' (i.e. even better throttle response) and smoother than the 7.5. The first time I briefly floored it (from about 40 mph, on a deserted road  :rolleyes:) elicited a "holy sh1T" response, so that probably tells you all you need to know. I can also confirm that the renowned GTI low end flexibility is still alive and well in the 8.5. You can tootle around all day at 30-50 mph without any issues and the start/stop system is well behaved when you are queued.
Ford Focus ST Mk 4.5
Gone: Mk 8.5 GTI in Dolphin Grey
Gone:2017 Mk 7.5 GTI, manual, black.
Online JoeGTI
« Reply #11 on: 06 December 2024, 19:49 »
As for returning to "comfort mode" - you mean the engine isn't it sport? It will remember the rest every time you start (steering, lighting, dcc settings etc) either via the sport or individual modes.
I just wanted it to retain the Individual setting permanently (Driving dynamics = S, Steering = S, Drive = C, etc). I checked the manual and it confirms what I said: "The vehicle system settings are reset to the Comfort driving profile when the ignition is switched off and then back on again". Just to be clear, it remembers what I have set within 'Individual' but I have to reselect it every time I get in the car. The other thing that's a bit irritating is that the driving mode/profile is not displayed anywhere on the digital dash (at least I can't find see it in any of the different 'views' I have tried) so you have no confirmation. On the 7.5 it displayed the word "Individual" on the dash right in front of you.
Well thats annoying and definitely a change from the MK8. In my MK8, I have Individual mode selected too and it persists across restarts. The only thing I need to change is put the gearbox into sport as that always does default to D.
In the MK8, if you configure your main instrument cluster to show the Gear selection (S1, S2, M1, M2, etc) then the word “Individual” does display under the current gear. Its probably similar in the 8.5.
Offline fredgroves
« Reply #12 on: 06 December 2024, 21:51 »
Irritations? It’s a shame you can’t turn all the “driver assist” stuff with one button click
What stuff did you want to turn off? You can probably turn it all off permanently with OBD11...
Not possible with the MK8.5 at the moment afaik. Something to do with SFD2 protection.
Oooh so I've just read.
That's a bit crap
Offline fredgroves
« Reply #13 on: 06 December 2024, 21:53 »
For the mode visibility you could have it change the infotainment and light strip colours by mode?
Assuming they've left you with that...
« Reply #14 on: 06 December 2024, 22:02 »
Hadn't thought of that. I'll give it a try...
