Author Topic: Faults  (Read 10808 times)
Offline jonesltd
  • MK7 R
Faults
« on: 08 November 2024, 13:59 »
I have scanned my car with OBD Eleven and wow the faults I have are loads and need some help please:
P050700
P044100
P001100
P11A100
P11A900
P11AD00
P11AF00
What parts do I need? Is this linked to me needing to get my chains done?
I am so lost and have moved countys so I have no trusted garages up here.
Thanks
« Last Edit: 08 November 2024, 14:58 by jonesltd »
If you cant find it......Grind it
Offline Adam T7
Re: Faults
« Reply #1 on: 08 November 2024, 15:23 »
Where are you based now? Folk on here might be able to recommend a decent specialist?
Offline jonesltd
  • MK7 R
Re: Faults
« Reply #2 on: 08 November 2024, 15:27 »
Based outskirts of Leeds.
I dont have a massive amount of money so have wiped the faults but one has remained on P11AF00 even if I force it to be removed it wont? I am using OBDeleven not pro version though
Offline joe6
Re: Faults
« Reply #3 on: 08 November 2024, 16:31 »
The fault code is for the camshaft adjuster so linked to the chain problem you have identified.
Offline jonesltd
  • MK7 R
Re: Faults
« Reply #4 on: 09 November 2024, 08:23 »
I have been given these chains to ge: if I got these would it solve the faults?
Dear customer
Thank you for using our services.
This particular car wvwzzzauzgw251131 uses two timing chain kits and one for the oil pump
https://www.autodoc.co.uk/vaico/15269332?search=VAICO+Timing+chain+kit+%28V10-10023-BEK%29
https://www.autodoc.co.uk/borsehung/14173589?search=Borsehung+Timing+chain+kit+%28B18779%29
https://www.autodoc.co.uk/vaico/17232632?search=VAICO+Chain+Set%2C+oil+pump+drive+%28V10-5856-BEK%29
