Author Topic: Timing Chain Kit  (Read 8191 times)
Offline jonesltd
  • MK7 R
Timing Chain Kit
« on: 08 November 2024, 11:35 »
Hi
I am trying to source a timing chain kit and I have been told the car has 2 chains and both need replacement? I thought there is only 1 chain not too?
Could someone from here that knows what they are talking about.
I have been told from AutoDoc the above information but also been told a number of chain differences therefore I am worried what information they are telling me about the number of chains required.
I have been told to get this one? but dont know if I need to order 1 or 2?
[/img]
« Last Edit: 08 November 2024, 11:55 by jonesltd »
If you cant find it......Grind it
Offline Finglonga
Re: Timing Chain Kit
« Reply #1 on: 08 November 2024, 15:07 »
Personally I would be getting Genuine VW/Audi parts because of the quality for a timing chain. You would need your VIN number to get the correct chain kit.
Offline joe6
« Reply #2 on: 08 November 2024, 16:26 »
Probably worth replacing the chain guides and tensioner as well while it is stripped down.
Offline madstaff
« Reply #3 on: 08 November 2024, 17:08 »
I'm pretty sure there's 3 chains, a cam chain, a balance shaft chain (?) and an oil pump drive chain with all the associated guides and tensioners.
It's a while since I've done one.
