Author Topic: Unusual Electrical Problem. Help !  (Read 29660 times)
Offline JohnB7620
« on: 07 October 2024, 11:46 »
I  have a 2009 Golf Plus 1.4 GTI. The instrument cluster ( dash ) lights up correctly with everything working on first quarter turn of the key, but then has a complete power failure about 1 second after starting the engine. The engine starts ok and all other electrics are working. Bizarrely the instrument cluster lights up for about 1/2 second when I turn the blower on.
The battery is fairly new and I have just replaced all the fuses.
Has anyone got any ideas on what to try next?
Offline sipj
Re: Unusual Electrical Problem. Help !
« Reply #1 on: 07 October 2024, 12:35 »
I have heard before that this can be caused by a fault with the main light switch.  If you know someone else with a similar car, I believe they can be removed without any tools - maybe just turned in a specific way to release them.  Is worth a test.
Current: Golf GTI 8.5. Pure white/black, pan roof, Queenstown, DCC, HK, Area view, spare wheel
Gone: 2018 Golf GTI 7.5 performance pack with standard spec
Gone: 2016 Golf GTE 7
Gone: 2013 Audi A3 S-Line
Gone: 2010 Golf GT TDI
Offline JohnB7620
« Reply #2 on: 07 October 2024, 13:24 »
Thanks for that. I’ve just checked that out. No change.
Offline joe6
« Reply #3 on: 08 October 2024, 09:25 »
Had something similar on my mk6 that affected the radio. This required a new ignition switch. Switch bolts are one use only.
