Author Topic: GTI Cold start  (Read 15385 times)
Offline Redreels
Re: GTI Cold start
« Reply #20 on: 30 July 2024, 22:21 »
It looks like the clips are a different design and the rattle is coming from a different point. I will have a go at making something myself
Offline Redreels
Re: GTI Cold start
« Reply #21 on: 01 August 2024, 13:01 »
Not sure it’s worth posting as there doesn’t appear to be much activity on this forum but in the hope it helps someone else.
This video shows the actuator position when on a cold start. The rattle is clearly audible by then once the cold start procedure stops the actuator position changes (pulled in) and the rattle stops.
What I intend to do is find a suitable clip or circlip that I can fit on the actuator that will reduce/prevent the noise rattle without restricting movement
https://youtu.be/75v_TxInDYg
« Last Edit: 01 August 2024, 14:22 by Redreels »
Offline SuperScaff
Re: GTI Cold start
« Reply #22 on: 01 August 2024, 17:08 »
Deader than platform shoes   :cool:
« Last Edit: 01 August 2024, 20:31 by SuperScaff »
Offline Watts
Re: GTI Cold start
« Reply #23 on: 01 August 2024, 18:03 »
Keep posting then chaps/chapesses - problem is new ways of communicating, people moving on from the MK7 and not enough new people. Those like me that have been here a while have already discussed many topics over and over again so are less likely to get involved.
But don't give up, there's still plenty around with lots of experience plus people like yourselves have so much to give too :smiley:
Previously:
Offline Redreels
Re: GTI Cold start
« Reply #24 on: 02 August 2024, 18:27 »
Thanks for the encouragement. I am going to be hampered by the position of the actuator to try and fit a clip in situ.
Also when the rod is extended it appears to have more play but when the rod is retracted the gaps on the clip appear smaller. I am not sure if a clip would then restrict the movement of the rod.
What I do know is that the cold start rattle annoys the hell out of me
Online Adam T7
Re: GTI Cold start
« Reply #25 on: 02 August 2024, 20:12 »
I’ve had it on mine for a few years, only last about 20 seconds just after the revs settle down to sub 1k after start up, hardly notice it now.
But mine has a creak from the door seals that drives me insane so I feel your pain☹️
« Last Edit: 04 August 2024, 07:14 by Adam T7 »
Offline Redreels
Re: GTI Cold start
« Reply #26 on: 03 August 2024, 21:40 »
It just doesn’t feel like a premium car on cold start. It’s embarrassing as it sounds like the engine is pulling itself apart.
I am happier I have found the cause but the lack of access will make it difficult to prevent the rattle
