Author Topic: URGENT!!! Subframe  (Read 2311 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: URGENT!!! Subframe
« Reply #10 on: 24 October 2005, 18:49 »
lol
Offline Fraiser
« Reply #11 on: 25 October 2005, 17:24 »
Rob if you need to come look at a finished item come and see me ( depending on haw far away you live)
Offline VR6_ROB
« Reply #12 on: 25 October 2005, 18:29 »
your near london aint you
im in north east i coudl do with some pictures though
as i cant seem to bolt the subframe up bolts seem to short now
Offline VR6_ROB
« Reply #13 on: 26 October 2005, 12:53 »
i can bolt in the front of the subframe but the rear wont at all anyone
got a picture of the rear subframe bolts or sizes just ot know if i am using right bolts
i cant find nomore though
Offline Fraiser
« Reply #14 on: 28 October 2005, 20:03 »
sorry i havrbt got no pics but i would assume you are using a mk3 rear subframe  - do you not have he bolts with it..
Offline VR6_ROB
« Reply #15 on: 28 October 2005, 22:34 »
nope subframe came attatched to engine
i have sorted it now though some metal was bent from when i was getitn new bushes in
squashed it all back up now and bolts fit
Offline VR6_ROB
« Reply #16 on: 02 November 2005, 20:23 »
is the vr steering rack same as my gti one as i want to change it
think ive done something to my gti one as they is bit of fluid comin out
from where them big links think its steering column goes onto the rack
Offline Fraiser
« Reply #17 on: 03 November 2005, 10:39 »
if you are going to keep the 4 stud set up you need to keep your mark 2 rack. - however if you are going to go 5 stud then u can use the vr rack.
have a look here
http://www.edition38.com/board/viewtopic.php?t=20274&postdays=0&postorder=asc&start=15
« Last Edit: 03 November 2005, 10:42 by Fraiser »
Offline VR6_ROB
« Reply #18 on: 03 November 2005, 18:36 »
sh!t i did not want to read that i might chance it and hope its ok
but if its buggered gonna be a right chew on to swap
i want to keep 4 stud set up thats all cant i replace the part i thinks
buggered with one off the vr one or dont thye come apart
