Author Topic: OE Springs, But What Dampers? OE OEM Bilstein Koni or Other?  (Read 49425 times)
Offline EB2019
Re: OE Springs, But What Dampers? OE OEM Bilstein Koni or Other?
« Reply #30 on: 04 August 2024, 11:45 »
Had a chance to take the car on a range of roads from 30miles dual carriageway and Suffolk B Roads.
Broken tarmac being the worst thing for any car is marginally worse now, but we are only taking worse in the context of Clubsport worse or RS3 worse. Not really Poly bushes or slammed worse, So a small trade off which I can easily live with and anyone getting in the car wouldn't notice, but I can after driving the car for a few years and driving straight after the replacements. The car feels more immune to harsh kickback through the body when going over expansion gaps in the road on dual carriageways, don't know if this is a consequence of new bushings or stiffer bushing but its a welcome solidness to the car at speed in a straight line. (The car is more taught).
On to the important part, when you initially turn into a corner, the car would previously make a smooth movement and correct your initial inputs as the soft suspension took up the slack and then it performs what's asked of it.  Almost two separate things in one turn of the steering, its subtle but was there before the changes.  I guess some if this is bushings/engine mounts, and some of its the high centre of gravity over the front axle.  Driving on B roads now the steering angle you apply feels more directly applied to the wheels and it feels like it moves in one single turn to the corner. Not sure how best to describe it but definitely better and offers a sharper more accurate feel to B road driving, you point it at the corner and it goes to that point straight away.
Physics still apply, its still lacking camber and this can only be over come with the CCS hubs or some form of NVH inducing top mounts etc. . But what has improved is the taught and responsive feel that was lacking before from the standard car.
Sorry to bore ppl but going down rabbit holes with OE + parts is fun lol :grin:
Replaced OE+
Front Arms
Rear Arms
Rear Anti Roll Bar
« Last Edit: 04 August 2024, 11:49 by EB2019 »
« Reply #31 on: 04 August 2024, 21:18 »
Nice update Emmett and the car is looking great too.
Sounds very positive thus far  :smiley:
Offline EB2019
« Reply #32 on: 06 April 2025, 21:34 »
I read recently that VAG standard suspension is like riding down stairs sitting on memory foam, I kind of assume they mean, it feels comfortable, but just can’t react to big bumps or undulations fast enough to support… or something.
This is one of the reason I wanted to switched to Bilstein monotube dampers, as a few of the cars I have had felt a lot better than the GTi in standard form, and while I was doing the shocks I replaced the ARB links and top mounts with Meyle HD ARB stabiliser links, and Lemforder top mounts.
Knowledgeable people at Bilstein.
For me the conversation was pretty insightful, and I thought I would share.
B6 and B8 are more similar than I thought.  One isn’t a sportier shock than the other, one isn’t stiffer or shorter than the other (at least not for the housing or piston length).
Until recently, I thought the B8 had a shorter piston rod so it could sit lower without bottoming out with lowered springs.  But after speaking to Bilstein it appears they are not actually like that, at least for the spec of cars I was asking about, A3, Leon, Golf etc.  The compression and rebound is the same, the housing is also the same, including the piston rod length. The only difference is the piston shaft doesn’t extend out of the shock as far as the B6, while the B6 will extend out like the factory damper at full extension, the B8 at full extension is reduced, with an internal spacer block, to prevent it reaching the same extended height as the B6 (shortened by a few cm).  This helps to stop lowering springs from coming loose under full extension (I.e. jacking the car up or massive hump back bridge jump) and not passing TUV or MOT.
So a B6 and a B8 will both work with the same lowered springs under compression and you won’t bottom out a B6 any more than you would a B8, however under full extension or ‘droop’ the spring could rattle loose with the B6 if the springs are 35mm lowered or more, hence the B8 option.  Bilstein informed me that in all honesty the Eibach springs are TUV with the factory dampers to work at full extension as well with B6, if I wanted to change in the future to lower Eibach springs.
We had a brief discussion about Bilstein B4 dampers which aren’t 10% uprated (even though it seems a very common myth on forums). They feel stiffer because they are replacing worn dampers with new most likely, but are simply OE matched..
Alignment done at my local Kwikfit with the Hunter alignment they all seem to have now, seems pretty good, I think?
B6 Bilstein dampers with factory GTI springs.
With the OE GTI setup I would hit a dip and belatedly the car bumps up beyond normal rebound and then drops back down, slow to react and takes time to settle.  If you often drive on country roads you might now what I'm describing, the car is mostly composed but it can get bucked about sometimes on the UK’s very country, country roads. The Monotube B6 dampers give you a more controlled initial cornering roll, while handling the bumps of B roads supportively. I was surprised they aren't more harsh tbh, and I was gearing up to switch out for something else, but i'm very impressed with the ride comfort and control. With the B6 You do feel broken tarmac the same as OE, and sometimes the B6 can give you a slightly louder thud on harder hits.  This is a little inconsistent and hard to define and repeat sometimes, but it must be part of the valving inside or my stiffer bushings,  however I have a few suspension upgrades beyond the rear shocks so its likely an incremental noise increase from OE, this is the only negative I can get from the dampers. Motorway speed is the same as OE but the slower compression and rebound making it feel 10-20% more taut, but not stiff.  Its a really nice feel (like my old M2 or B16 on the GT86) without being harsh at all, and with no increase in NVH and a flatter initial turn, I have far more positives than negatives.
Melye 4 year warranty ARB Links with much bigger ball joints.
Lemforder Top Mounts
« Last Edit: 07 April 2025, 20:15 by EB2019 »
Offline Paul70
« Reply #33 on: 07 April 2025, 15:55 »
Interesting read as always EB2019.
I am sure someone will ask, so I may as well ask. Has the ride height increased?
Curious as to why you decided aftermarket for the other parts and not OEM - are they stiffer so less deflection, or was it price driven?
I am sure your car handles very well now with all the mods - just need another degree of front camber to liven things up a bit. On the subject of alignment, it looks good to me - front camber is the most aligned I’ve seen on a standard car!
Any further mods planned?
2026 Golf GTI ED50
Offline EB2019
« Reply #34 on: 07 April 2025, 20:02 »
lol ride height, the elephant in the room!
Its 3-5mm higher I believe, right now 100 miles of fuel range. 365mm front 374mm rear. I can live with that, as it doesn't look like it sometimes, and then I look at it again and I think it shows, its very subtle and probably only with a static side by side would I be able to see it. I think I originally measure it with 50 -70% fuel load at 360mm and 368mm prior to fitting. The picture at the top of the page was before fitting, but the car was on a slope from camera position to passenger side so it wasn't flat and likely to have made it look higher than normal, I might go back to that location and take another shot if I think about it.
Regarding parts, OEM is an interesting one, its partly price but I don’t think I compromise moving away from VAG for some parts. VAG are mostly just assembly plants, VW ‘make’ very little. Our Injectors are Bosch or Seimens, my pollen filter was Valeo with a VW logo next or it, airfilter was Wix genuine from the Factory, clutch is either Sachs or LUK, brake pads are TRW but the CSS pads I have are genuine VW with a Ferodo logo, CSS discs are Zimmerman, wheel bearings are likely to be FAG or SKF.  So for me, as long as I can source from a leading Germany brand I’m happy and I can cherry pick.  In the case of my top mounts I went for ZF (lemforder). I had a Febi top mount and ARB link in my hands prior to purchase, and they appeared inferior to Lemforder and Meyle HD links.  I remember the Lemforder logo (it looks like an Owl in a triangle) on lots of German OEM cars parts over the years and when you handle the parts you can see why ZF and Lemforder are used. I'm in a fortunate position of being able to get access to parts from Sachs ZF and Lemforder Febi LUK Mahle etc.
Meyle HD stuff is great https://www.meyle.com/en/product-lines/meyle-hd/
Geo is pretty good like you say, my subframe must be right in the sweet spot.
Future plans, are to leave it alone now and enjoy! Although I do need, sorry, want a little more camber, I can't justify the cost for 1-2 degrees for the CSS hubs, think they are £500 a hub now!!
« Last Edit: 07 April 2025, 20:10 by EB2019 »
« Reply #35 on: 08 April 2025, 18:10 »
Another excellent update Emmett.
The results pretty much as hoped for - improved body control and tautness.
I agree with your sourcing of components as an upgrade over the OEM fitted parts that are worn. The OEM parts are of decent enough quality but are built to a cost despite their retail costs being quite high as replacements, where as you can purchase better quality items for less money that haven’t had to go through the VW official system which inevitably hikes the retail prices up.
Offline Budwab
Any chance you could help with what rivnuts are needed for the new rear arms EB2019?
Many thanks
Issac Blue GTi PP DSG; Art Velours; Dynaudio; Reverse Camera
Offline EB2019
Sorry pal on hols at the moment, will have a look when I get back but will be away for a couple of weeks.
Offline Budwab
No rush
