Author Topic: buying advise on a mk 7.5  (Read 5577 times)
Offline v8rumbler
« on: 15 March 2024, 09:43 »
I am in the market for a MK7.5 Performance DSG. Can someone please post the service schedule so I will be able to check any car has been properly maintained.
Also how long do water pumps & clutch last etc etc
Offline Yusee
Re: buying advise on a mk 7.5
« Reply #1 on: 15 March 2024, 15:36 »
This is the best  service schedule I’ve come access..
https://www.shopdap.com/blog/post/service-schedule-for-mk7-5-gti-2018-2019.html
Leaking Water pump and thermostat housing is probably the most commonly reported fault on these cars, you can probably expect to do this at some point.
Standard clutch is also reported to be weak, obviously depends how the car is driven
Offline Adam T7
« Reply #2 on: 15 March 2024, 16:25 »
I understand the clutch(es) on the DSG are pretty hard wearing?
Offline Yusee
« Reply #3 on: 15 March 2024, 20:25 »
Not sure about the DSG, Adam.
I’ve seen comments on here about the clutch on the manual- described as “ chocolate “
Mine has been fine so far- at 30k miles
Just noted OP in market for a DSG, so ignore what I said about the clutch!
« Last Edit: 15 March 2024, 20:28 by Yusee »
Offline v8rumbler
« Reply #4 on: 16 March 2024, 06:49 »
Thanks for that - a very useful site.
Prices are all over the place atm. some private sellers are asking the same as trade outlets.
Offline Morris6145
« Reply #5 on: 18 March 2024, 17:51 »
Adam. I have a well maintained Mk7 66k DSg last DSG oil change 40 k. Box has failed therefore 5k just for a reconditioned box plus vat plus fitting. Water pumps also a weak point in excess of 900 to fix as it involves a lot of dismantling of the engine.
I'll let you decide fine if it's warrantied but don't buy one without
Offline Jace
« Reply #6 on: 19 March 2024, 09:40 »
80,000 for the 7.5 7spd DSG service, but maybe do it 60-70,000 mark to be ahead of the game.
Clutch packs, depends how you drive.
Water pumps, you only hear of those that fail, not those that are 100,000 plus like a friend has on his .
2018 Golf R 7.5 Estate > Full Revo stg2 set up
Offline Morris6145
« Reply #7 on: 20 March 2024, 20:35 »
Think we should nominate your friend the 'rocking horse sh!t trophy,' for their water pump not failing. Every dealer /independent will tell you this is a very common repair. More common than not. Happy to be corrected
Offline Legacywr
« Reply #8 on: 03 April 2024, 18:27 »
Could be selling mine soon, full VWSH, serviced in January.
