Author Topic: Mk8 Golf rear camera retrofi  (Read 26859 times)
Offline GE90
Re: Mk8 Golf rear camera retrofi
« Reply #10 on: 11 March 2024, 14:59 »
Great photo's - thanks J3!
A big ask I know, but do you have a guide or write up please, perhaps also covering the tweaks requires with VCDS?
Offline Gazzza45
  • Clubsport45 Moonstone
« Reply #11 on: 13 March 2024, 12:08 »
That’s impressive…….think I’ll stick to the beepers though :grin:
« Reply #12 on: 13 March 2024, 17:41 »
Good work J3, a nice detailed photo walk through that’ll either inspire others or scare them off!!  :whistle: 😁
Is the camera resolution good considering its origins?
Offline DSGboy
« Reply #13 on: 14 March 2024, 11:13 »
Great set of pics, thank you. Wow, what a lot of work, can see why cost to retrofit at a specialist is priced as it is. As others have said, pleased I specced miy R  new.
Must say. Not had a Rear Camera before, but find it Sooo handy.   Would buy again and would consider 360 Degree View and Parking Assistant and Rempote parking facilities.
I’m a Wheelchair user now getting tired of inconsiderate,selfish….just poor/bad parking.  Even on this yellow slatted areas bordering Disabled bay at a Hospital yesterday.   And they are NEVER just 5 minutes.  Grrr.
Gone. Mk6 GTI DSG, 2012 ,5dr , DPB, 18’s, Leather, Dynaudio, Cruise, DAB, Auto Mirrors, Storage Pack, TPMS.
Current. Mk7.5 R DSG, 2019, 5dr, DPB,  Pretorias, Leather, Memory Seat,  Climate Screen, Rear Camera, Black Caps
Offline simonwhite2000
« Reply #14 on: 07 May 2024, 13:56 »
Epic job and I wish I had the stones to tackle a job like that.
I actually got some quotes for getting one fitted and best I could get was £550 - so it was a no for me!
As someone else said you could probably make a few hundred quid per one fitting a few of these.
Awaiting: Mk8 GTI CS
2020: BMW 840 Gran Coupe
2017: Audi B9 S5 Coupe
2014: Mk7 Golf R manual
Offline Basik9007
« Reply #15 on: 20 September 2024, 20:21 »
Hey J3
Great detailed install, in thinking of installing the same camera, was wonder, what you used for coding, also do you have coding list that you can help me with.
Thanks
Offline J3 hnn
« Reply #16 on: 20 September 2024, 22:50 »
Module 5F
Change vehicle function list BAP-VPS 0x0B to Activated
Vehicle function list BAP-VPS 0x0B msg Adjust bus to CAN-FAS or Terminal 15
Adjust parking system input to 1392x656
Function configuration unit adjust RVC video input to Ethernet
Module 19
Long coding
Byte 20
change to RVC Compact smart
Installation List
Check both cameras 6C
This is the coding for it. I got it coded using obd11 pro. As vcds couldn't do it because of some issue with module.
Offline GE90
« Reply #17 on: 07 February 2025, 16:28 »
I'm thinking of tackling this myself. Just a few queries first if you don't mind!
Is it possible to code this with genuine VCDS, or is there an access or security issue still with MK8's?
Any tips on where to buy from? Do they always come with the loom and instructions etc?
Any tips on removing the boot hinge rubber/plastic boots without snapping them?!
Cheers.
Offline J3 hnn
« Reply #18 on: 10 February 2025, 01:17 »
Hi not been on in a while, vcds apparently can't code them because sfd protection, so I did buy a obd11 to code it.  I ended up removing the camera as I was sent a left hand drive camera so got my Money back and I left the loom in for future fitment of the correct one. The AliExpress cameras seem to be good I have been checking eBay ect for one to pop up. I did buy a rear camera from vmodul for my Tiguan and that came with loom instructions ect https://vwmodul.com/product/rear-view-camera-for-vw-golf-8-right-hand-drive-version-8ar/?cn-reloaded=1
As for the grommet I would recommend trying to remove it warm ie get some heat to it like hairdryer or something to prevent breakage, I luckily had one I bought for my twiggy which was same part. I've just not got round to fitting a new camera yet but when better weather arrives it's on my list.
Offline GE90
« Reply #19 on: 10 February 2025, 07:36 »
Thanks very much, appreciated.
Sorry, just a few more questions!
How did you remove the pins from the large gateway plug? Pin removal tool?
How should the power connect to the fuse box?
Installers are suggesting that the camera should be calibrated in addition to the coding. This can apparently be done prior to installing. Any thoughts?
Is the SFD lock something that can be removed with OBDEleven permanently, meaning that my VCDS will then work?
Thanks again.
