Author Topic: Stock Performance Pack disc and pads  (Read 9377 times)
Offline jh_97
Re: Stock Performance Pack disc and pads
« Reply #10 on: 08 April 2024, 22:03 »
Yes exactly, that's why I'm curious why the sensor hasn't flagged anything if they really are that low.
Interestingly, I double checked my invoice from the check... It says front brake pads on arrival were 5mm, but then at the bottom they need renewing as they're 1.6-3mm left... Perhaps this is why the sensor hasn't triggered anything  :grin: They did also state that the tyres I've had on for less than 1000 miles are all 50% worn as well...
Happy to be cautious and change them anyway, just interested about the sensor
« Last Edit: 08 April 2024, 22:27 by jh_97 »
2018 GTI PP DSG, Pure White, graphite Sevilles, Art Velours
Offline jh_97
« Reply #11 on: 10 April 2024, 13:39 »
Just bumping this up again in the hope someone knows the answer..!
What remaining thickness do the brake pad wear sensors trigger?
Offline Agreeable Slick
  • Unit
« Reply #12 on: 10 April 2024, 13:52 »
Depends on how well the wires are seated.
Nominal is usually around 2-3mm, but they can be higher or lower. It should create a short when you remove enough friction material to expose the wire and wear that down.
Offline jh_97
« Reply #13 on: 10 April 2024, 14:25 »
Thanks!
