Author Topic: Thinking of buying new?  (Read 29002 times)
Offline davo245
Re: Thinking of buying new?
« Reply #40 on: 22 February 2024, 22:19 »
The problem with BEV range is that its down to a lot of factors....
it performs better in stop start urban driving and not motorway (yes counter intuitive for ICE drivers)
Things like having the heating on really kills the batteries (an electric heater is all you have.... no heat from the engine!)
Lastly ambient temperature effects the battery - cold is very bad.
So a typical UK cold wet winter with you having the heating, lights, windscreen wipers on etc and trying to go down the motorway.... the range is really going to drop right off.
I'm sure MonkeyHanger wrote a lot about his BEV experiences on here - which pretty much align with other opinions.
Pretty certain that newer battery tech will fix this, but when is it coming? Its always "soon". Its supposed to be faster charging (assuming you can find the right charger...), longer range, lighter and less vulnerable to cold problems.
Which then gives me uncertainty about buying old tech that will be worthless once the new batteries come along.
I've already got the current quickest Born, the v2 e-boost 231ps, so I can let you know first hand about efficiencies.
Cold weather kills efficiency on EVs, because the battery array needs to be warmed to use it. For short journeys e.g. 2 mile school run, the battery warming takes as much energy as moving the car. At 0C, on that 2 mile school run, I'm lucky if I hit 2 miles per kWh. It's 4 miles per kWh in the Summer.
On a long motorway run, in Winter, eventually the battery warming effect wears off and you can get around 3.0 miles per kWh sat at 70 on a 100 mile+ run if you have the cabin heating on a minimum 16C. If you need cabin heating like a reptile does, figure more like 2.6 miles per kWh. In the height of Summer, you can do 3.9 miles per kWh sat on the motorway with the aircon on.
The "new" battery size of 79kWh seems the same as the old one, with less headrace. All batteries are bigger than their stated capacity. This one has an 82kWh actual capacity, with 77 or 79 kWh usable (this is to prevent overcharging or thermal variation overloading cells), mine is the 58kWh variant (usable), with 62kWh actual capacity.
Given its weight, the Born is quite agile (compared to pretty much every other BEV out there), but it's like chucking a bog standard Golf about, it's no chuckable hot hatch. Given that the 77kWh battery pack Born weighs in at a hefty 1970ish kg, this is no GTI.
If you scale up my figures for the bigger battery, you're talking a realistic 213 motorway miles at 70mph in Winter for this car with low heating, charged to 100% down to 10% before you really feel you need to stop for a charge.
Figure 277 Summer motorway miles on same terms. Knock 20% off these figures for driving at 80mph. Rapid charging costs about 79p per kWh motorway adjacent right now, so your costs per mile go up by a third in Winter. 20p per mile away from home in the Summer and 27p per mile in the Winter - dearer than fuelling a Golf R/S3.
For me, BEVs only make sense if you have a home charger and very rarely venture beyond its range. No-one is buying BEVs privately brand new right now, it's just fleet sales, as a result, the depreciation is horrendous - these cars on PCP will be handed back at a loss, worth about 80% of the HFV quoted for ours. When we bought ours 2 years ago new, GFV was about £21k at 3 years, Motorway value it at about that now. If you buy a BEV, don't buy new, they lose too much, grab a used bargain.
Most BEVs with amazing 0-62 times are one trick ponies and handle like sh!te outside a straight line. My nate just leased a Smart #1 Brabus with 3.8s 0-62, but it corner like a double decker bus, and looks like a Golf sized Vauxhall Adam. :sick:
Makes a change to read an honest EV review instead of the usual (well I bought one so must justify to myself I made the right decision even thou I regret it)
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline AndyGTI
« Reply #41 on: 22 February 2024, 22:24 »
Thanks @Monkeyhanger. It’s good to see your thoughts again and it’s interesting to read about your experiences with all your vehicles.
Would you say in addition to the urban driving being better suited to EVs, is A road travel a good use of an EV (putting aside handling question)
Yes some of the ultra rapid charger (and even fast charger) prices are ridiculous from what I have seen. What I do find interesting is the Tesla superchargers which are Open to all are down in 51-59p per kWh range (lower if you take out the monthly subscription but that is only worth it with doing a lot of miles).
I notice a lot of VAG group were doing or are doing 0% PCP but these are mainly end of line before facelifts.  But do you think a 0% deal (2 or 3yr) would make some sense? But would the GFV have to be a reasonable level or else your monthly payment is just covering the huge depreciation the EV would sustain.
It’s just interesting to see the evolution of the EV happening and now that more “normal” cars are appearing as EVs rather than constant stream of SUV derivatives makes it more interesting.
I do have a drive so home charging would be possible but the wider charging network for those times when you have to stray beyond your range does mean you need to go into it with your eyes open.
Don’t think I would be jumping this year, but it’s just interesting to read your own real world experiences and so interesting you got back into ICE via the S3.  how are you enjoying it?
As @Hertsman has already said with cost of new cars, mine is more than likely a second hand one.
2022 Polo GTI, Reef Blue
2022 Audi RS3 Tango Red
2016 Golf R 3dr Manual, Lapiz Blue
2013 Polo BlueGT 3dr, Blue Silk
2007 Polo GTI 3dr, Diamond Black
Offline monkeyhanger
« Reply #42 on: 23 February 2024, 06:52 »
For me, the best thing about EV driving is remote car preheating  in the Winter.
I would say that if you have no possibility of home charging, don't even think about an EV until you have to.
They drive fine in a sterile sort of way, as I said, a one trick pony in the 0-62 times for most of them, but it requires no skill at all to launch. Even the mundane EVs will beat most exotic petrol cars 0-20mph - instant full torque from 0 rpm.
Something I didn't mention is that this new Born will weigh about 160kg more than mine due to that bigger battery, I can't see VAG being able to hide that weight with better handling than the 58kWh version that I have.
The Born (and ID3) are a change from the usual SUV horde of EVs, and inside it's got an interior as big as a Passat (less bonnet, more cabin).
They drive fine for no thrills driving. Until they can get battery tech that allows for 1500kg kerb weight to make them nimble, driving a powerful EV is going to be like driving an unladen Arctic lorry cab.
The brake regen is fairly effective at levelling the playing field on terms of an uneconomic driving mode. I'm 20% more efficient than the wife in the S3 (good anticipations, coming off the accelerator earlier rather than braking late). In the Born, there's 5% between us. It doesn't replace braking, but I'd say 80% of my slowing down in the Born is covered by regen, which is about 70% efficient in recovering momentum rather than converting it to brake disk/pad heat.
The residuals on BEVs are too shaky right now to buy a new one. Buy a 2 year old one for half price (or less). I wouldn't have bought the Born new if I'd known how far the residuals would tumble.We bought 2 Borns off the back of buying 2 ID3s at a bargain price (£28k paid, on a £36k RRP) in 2021, and selling them a year later for £38k (where trade were selling them to Uber drivers for £44k as the Ukraine war had buggered supply of key components).
We bought 2 Borns at the height of the bubble for full RRP (£38.5k), so man maths says they only cost us £28k.
After getting a job that required a once a month 480 mile round trip, that Born commute became a PITA - rapid charging prices doubled, as more people got EVs, there seemed to be a 60% chance you would arrive at a charger due to necessity, to find it occupied and having to wait to get on it, and then wait 40 mins for the actual charge - I just wanted to get home. I sold my Born (wife kept hers, and it works well as a second car) at a time that almost no trader was touching BEVs, following Teslas shock £9k RRP drop absolutely devastating used values and leaving a lot of traders out of pocket. I got £31.2k for it a year old and consider myself lucky to get that, had to really ask about to get someone to buy it.
I do think that everyone who wanted a new BEV with their own money has had their curiosity satisfied and have generally been stung. The supply of new BEVs is pretty much just company cars propped up by rock bottom BiK.
My neighbour has his own business and got a Merc EQC 400 EV through it. The lease was up next year, but he gave it back early to get a Ford Ranger Thunder double cab pick up - read into that what you will.
« Last Edit: 23 February 2024, 07:09 by monkeyhanger »
Offline jh_97
« Reply #43 on: 23 February 2024, 07:17 »
[/quote]
But then the problem with this is the reduced maximum capacity for a BEV that's been used for a couple of years or more as you have no idea how the previous owner has looked after the battery. If they've always depleted it fairly quickly, used fast chargers regularly, and not tried to keep it between 50 and 80% charge, then the max capacity will be far less than when new  :shocked:
They need make it easy for the cars to show the current max capacity, and it should be advertised when selling a used BEV!
2018 GTI PP DSG, Pure White, graphite Sevilles, Art Velours
« Reply #44 on: 23 February 2024, 08:21 »
[/quote]
The newer generations of batteries are more robust than the ye olde Nissan Leaf/Renault Zoe batteries with no temperature management and different battery chemistry. If there's a battery hammered by rapid charging, it'll likely have a high mileage. The current crop of batteries have an 8 year warranty - you're on shakier ground buying an out of warranty 9 year old battery vs a 2 or 3 year old BEV.
Offline fredgroves
« Reply #45 on: 23 February 2024, 08:33 »
I'll bet the battery warranty isn't transferable if it's a VAG...
« Reply #46 on: 23 February 2024, 11:14 »
Apparently it is. Needs to still carry 70% of its rated charge at 100k miles or 8 years, whichever comes first. They don't need to replace as a whole, just swap out enough cells to get you back over the 70%.
« Last Edit: 23 February 2024, 13:37 by monkeyhanger »
Offline fredgroves
« Reply #47 on: 23 February 2024, 13:01 »
Blimey you could knock me down with a feather!
Offline fredgroves
« Reply #48 on: 23 February 2024, 20:30 »
Earlier we talked about alternative hot hatches...
So not these as a choice..
https://www.evo.co.uk/hyundai/206546/hyundai-i30-n-and-i20-n-axed
Offline AndyGTI
« Reply #49 on: 24 February 2024, 05:35 »
Even Hyundai with i20N & i30N seem to be on shaky ground. it was a year old but I watched a video report that suggested Hyundai was not going to keep them going. Neither are available to order from factory at present. Although there has been autumn sightings of i30N there doesn’t seem to be any certainty of it being for Europe. So who knows. at present it’s under £40k but any new model might go through barrier if anything does launch,
Oh no, Another (two) bite the dust.
It’s not a surprise but that is a shame, but @Fredgroves I remember you commenting after a test drive about the engine tech not being as advanced as VW and the pretty terrible economy. But end of an era (ok they were only around for 7yrs and they proved they could do it.
the choice is getting limited VAG Group, BMW, Toyota.
