Author Topic: Mk6 gti 3 cylinders :(  (Read 29297 times)
Offline Nino
  • Insta - F6UGA
Re: Mk6 gti 3 cylinders :(
« Reply #10 on: 11 December 2023, 17:27 »
Hey Chuck,
I faced a similar issue with my R32 a while back. It was misfiring pretty badly even after I replaced the coil packs and sparks (not exactly easy on the wallet when you need six of each). The misfiring errors persisted even after scanning, and I was getting frustrated.
Eventually, my cousin, who knows his way around cars, heard a slight hissing sound near the back of the engine. Turns out, there was a split air line going into the brake servo. I'd recommend thoroughly checking every single line under the hood.
If that doesn't uncover the issue, considering your love for the car, my suggestion would be to use a local flatbed service to take it to a reliable specialist. Unfortunately, you are far from Wales, but there's this fantastic place called "Euro Performance" here. Gareth and his team worked wonders, completing a full engine rebuild on my R32 in just three days.
This kind of work is their specialty, and if they can't fix your car, I doubt anyone else can. You might be looking at a few hundred for the flatbed service, plus the repair costs, and then the return flatbed. However, they'll book you in, fix your car, and it ultimately comes down to the investment.
If you're open to this option, tell them I recommended you. They'll treat you well, recognizing you as a fellow car enthusiast, although it won't necessarily get you a discount.
https://euro-performance.co.uk/
« Last Edit: 11 December 2023, 17:30 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline chuck43
« Reply #11 on: 19 December 2023, 19:15 »
The gearbox bit sounds like the rear main seal (crank seal) isn't sealing properly. This can cause issues like misfire. This normally fails as the PCV valve fails and there's too much pressure in the crankcase. Common issue on this engine.
Do you have an oil leak from the gearbox to engine join.
I'll have a look but sounds plausible. The pcv valve did go about a year before this happened. Ended up buying, a quick one on amazon as they'd deliver it on the Sunday morning and I could try find if was The problem before buying a oem one or a delete kit. I never did do either of them 😕
Any idea what the jobs like to do??
