Author Topic: Folding mirrors retro fit - Questions & Guide/advice  (Read 96551 times)
Offline Nino
  • Insta - F6UGA
Re: Folding mirrors retro fit - Questions
« Reply #10 on: 23 November 2023, 13:51 »
Thought I would post an update since I suppose others may be thinking about this.
So, over the past few months, been looking for cheap parts and researching.
Coupled with the info from Bluto (Thanks again) I decided to take a plunge.
I bought some 2nd hand Power folding mirrors on ebay I decided I wanted to get VW OEM ones and not the 3rd party ones.
NOTE: Don't worry about which ones you get. Just make sure they are power folding and have the puddle lights, they will work.
Just make sure you buy the Golf ones and NOT the Golf cabriolet ones as the backing plates are much more narrow.
I managed to find some baged up ones from a breaker on ebay for £65.
I then found trouble getting the Golf Door modules, there were ether to expensive or I just couldn't find them and again, I wasn't buying 3rd party ones ether.
So I took a punt and bought, VW EOS Sport 2DR CONVERTIBLE WINDOW MOTORS I found these seperately from different sellers and got them for around £19 each.
Final part I needed was the new window switch. Got this on ebay for around £13.
Now I could have stopped there, thats a full retrofit for £116.
I however wanted to upgrade/replace some parts
- New gloss balck mirror caps (not genuine £17.55)
Click HERE for link to buy.
- LED puddle lights (not genuine £11.39)
- New bottom parts to the mirrors including smoked black LED indicators (not genuine £13.02)
- New upgraded blue anti dazzle glass with blind spots. (not genuine £19.98)
Only part I am not massively keep on was that the indicators are dynamic sweep, I felt this is a tacky thing on an older car however, now its fitted, it has grown on me.
Total price for everything at this point is: £177.94 which I think is a good price for the upgrade.
Here are some pictures, I am sure you will agree.
What I have found however, is due to the modules being from a 2DR convertable, they were doing the window drop thing.
I had to use my VAGCOM to recode the modules and disable rear door modules (was enabled on the drivers one for some reason) and also disable the feature for window drop for convertables, passenger module also didnt have folding mirror or puddle light enabled. Once I did all this, I now have fully functioning power folding mirrors and I must say, I am quite pleased with myself.
« Last Edit: 23 November 2023, 13:53 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline joe6
« Reply #11 on: 23 November 2023, 16:13 »
Nice walk through guide Nino and good retrofit. I get fed up with manually closing the mirrors before garaging the car.
Offline Nino
  • Insta - F6UGA
« Reply #12 on: 23 November 2023, 16:16 »
I had them on my Mk7 GTD as well as many other toys but this is the only thing I miss from the MK7 so I had to do it.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #13 on: 23 November 2023, 18:33 »
Nice little upgrade.
Was never bothered by mine not folding but I do miss the mirror tilt down when reversing.
Current Garage:
35+ years of GTI ownership.
Offline Bluto
« Reply #14 on: 23 November 2023, 22:31 »
You've been rather busy there @Nino.   :cool:
Looking good, glad everything looks to be playing nice, despite a little bit of VCDS coding.  Great result chap.
Mk8 GTI Clubsport | Pure White | DCC | Black Estorils | HUD | a fair few options
Previous: Mk6 GTI | Candy White | Manual | DCC | Dynaudio | Cruise | Winter Pack | Lux Pack | Rear Camera & F/R Parking Sensors
Offline Nino
  • Insta - F6UGA
« Reply #15 on: 23 November 2023, 22:31 »
Yeah, I haven't sorted the mirror dip bit yet, on the list to sort it.
Offline Nino
  • Insta - F6UGA
« Reply #16 on: 23 November 2023, 22:32 »
Thanks mate, you helpped.
Offline Nino
  • Insta - F6UGA
« Reply #17 on: 26 November 2023, 23:47 »
Tiny update:
Got the mirror dip working on reverse.
Everything works exactly as it should apart from 1 thing.
Whenever, I unlock the car or open the drivers door, both the passenger window and drivers window drop about 1cm as if its a convertable.
Soon as I close the door/lock the car, the windows both go back up.
I have disabled the convertable "window drop" option in Vagcom on both modules but it still does it.
I guess its hard coded somewhere into the modules as they came off a convertable.
Don't suppose anyone know another way I can solve this?
Offline Nino
  • Insta - F6UGA
« Reply #18 on: 11 December 2023, 16:55 »
Right, I have cracked it.
So, the Modules come as two seperate sections.
When we scan them with VCDS, you dail into the motor part number and not the module with the A on the end, the A just adds more features.
So, for the Golf, You will notice looking at my part numbers, they match Bluto's earlier scans accept his is the C version not B version like mine. where as because I have used new modules from a Sirocco & EOS Golf both of which are pillarless, the movment is hard coded into the Motors themselfs.
The motor part numbers on these were:
  • 1Q0 959 702 H
  • 1Q0 959 701 H
The Golf Part numbers are:
  • 5K0 959 702 C
  • 5K0 959 701 C
I have managed to code them so while they will open 1cm when I unlock the car, once I get in and close the door, they go back up, they also drop when I remove the key from the ignition.
While it is slightly annoying, I can live with it for now.
I will in the meantime, continue to look for replacement GOLF modules and replace them around in the spring.
For anyone reading this and wanting to do it, you MUST ensure that you buy Golf ones, look at the picture below of my OEM ones, I have editied the picture the ones you want to look for to be compatatble with Folding power mirrors.
Hoppe this helps others to not make the same mistake I did  :laugh:
Offline Nino
  • Insta - F6UGA
Re: Folding mirrors retro fit - Questions & Guide/advice
« Reply #19 on: 03 March 2024, 16:58 »
Finally fitted the new units, coded and boom, no more window drop, mirrors fold & dip in reverse as they should too. Everything now working, can put this to bed!
« Last Edit: 03 March 2024, 18:21 by Nino »
