Author Topic: Best wheel protective wax.  (Read 3331 times)
Offline Adam T7
« on: 25 September 2023, 18:48 »
Just about to get my Parker’s powder coated, diamond cut and lacquered so (fingers crossed) they will come back factory fresh.
So, to the knowledgeable wheel and detailing folk - what is the best protector to stop dust / crap build up and also avoid ‘browning’ of the black parts of the wheel?
Previously, used Dragon Breath Ph neutral cleaner and Dirtbusters wheel wax, but looking at some of the examples on here (i.e. Willni) I guessing there’s better products / process?
Offline willni
Re: Best wheel protective wax.
« Reply #1 on: 25 September 2023, 19:15 »
You rang  :wink:
My first recommendation is to ditch the wheel wax, it's too much work for short term benefit. A ceramic coat is the same work but lasts over a year vs a wheel waxes 1-2 months.
If you do this, then apply the ceramic to the barrel (behind the spoke) and level it out so it's even but don't buff it off, it will leave a thicker layer which means more protection that lasts longer as you'll never see inside the barrel you don't need to worry.
Maintenance wise I spray my wheels once a month with Gyeon WetCoat (I do the paint as well), this is effectively a sealant that you just wash off, and helps keep the dirt from sticking.
Apart from that, PH neutral wheel cleaner then iron remover once a month and you'll have clean wheels.
Also in winter if you can hit the wheels just with a blast of water to get the worst off once a week (you don't need to clean them) this stops contamination from bedding in.
Follow this as if you have gloss wheels unlike me, you'll be able to just hit it with a powerhose and 90% of the dirt will come off, at least for the first few months.  :smiley:
Offline Adam T7
« Reply #2 on: 25 September 2023, 20:14 »
Nice one, thanks.
What initial Ceramic do you recommend?
Offline willni
« Reply #3 on: 25 September 2023, 21:15 »
Nice one, thanks.
I personally prefer Gyeon Rim, in fairness I'll happily recommend anything Gyeon you pay a little more but it's all very good.
Otherwise I know another popular one is KKD Revolve.
Get a pack of £1 make up pads from boots or steal them from your better half they're pretty ideal for applying to the wheel faces and spokes.
Offline Adam T7
« Reply #4 on: 26 September 2023, 06:13 »
